Hi everyone
i tired simatic pc access opc server with wincc and i connected s7-200 opc server wincc programs but pc access program have 60 day trial wersion..
i finded plc.net.ru "pc access" program crack but i dont find it later
i did download kepserverex setup and i did intall my computer.. but i cant find kepserverex commination setting usb.. i have USB PPI cable
how am i s7-200 plc to kepserverex(USB) to wincc ??
[?]: KepservereX Work Usb ??
ilhano1978
ilhano1978
Why don't you try this one:
http://plc.net.ru/viewtopic.php?t=5843&highlight=access
and then download SP3 from Siemens site.
Anyway, my experience shows that Kepware has better OPC. If you wan't to use PC Access keep number of PLC's low, and use only directly wired connections (no GPRS/3G or internet).
auto_mitch
May be you should use modbus OPC server (matrikon or some free software). S7-200 can work as modbus slave, just download and use this library [dead] :/30955650/In ... ibrary.nrg
ilhano1978
i use device driver" siemens s7-200" ..but this device driver havent usb..this device driver have com1....com100..auto_mitch wrote:Which driver do you use in Kepware is it s7-200 driver?
You can select the communication port COM1,...,USB.
kepware program have other device driver (siemens mpi and siemens tcp/ip .... ) but all device driver havent usb work..
