Hi everybody.
Can somebody tell me what meen "interrupt", when i use , for example OB30.
I use CPU312C with FC105 scale function to read analog values and store in DB.
I think OB30 meen that the program will read from sensors every 5 seconds.
Is this correct??????
How to increase that time, for example,30 sec?????
[?]: How to increase time OB30????
bunglehead
Re: OB30????
That's perfectly described in builtin help. Don't be shy to use it.Ilija28 wrote:Hi everybody. Can somebody tell me what meen "interrupt",when i use ,for example OB30. I use CPU312C with FC105 scale function to read analog values and store in DB. I think OB30 meen that the program will read from sensors every 5 seconds. Is this correct?????? How to increase that time,for example,30 sec?????
Re: OB30????
?????. This was answer????? OK,thanks
