[?]: problem in openning Wonderware backup project
Vishal
Post by Vishal »
hi friend i am trying to open project back up of Wonderware 9.5.
When i open in Touch application manager in the project description it shows me APPLICATION DENIED.
it is not allowing DB bump anf db load and runtime option are disable.
when i try to open window maker it show me message that application (Application path ) access denied.
can any one help me out then plz reply it
i think you make backup project with maker open.
check if in root of project directory you have present file " wm..."
i do not remember name of file
this file WindowMaker
you need delete it
Umencho
Post by Umencho »
File shoud be with extension *.loc. Delete this file. This happen when you create backup of the project with active Veiwer.
Best regards
Vishal
Post by Vishal »
i am have search that file it is not there...
sania wrote:i think you make backup project with maker open.
you need delete it
there are mainly WVW,WIN And WBK files so which file should to be delete ?
i say about *.loc
check if your directory & files not read_only
