[?]: connect encoder omron to FM350-2
FVSOLO
Post by FVSOLO »
now i use encoder omron(type: E6C2-CWZ6C) that is NPN type it have five lines so i use brown connect with 24Vdc,Blue 0 Vdc ,Black(Phase A) connect to Chanel A0 of FM350-2 and i test rotation shaft of encoder by hand and see counter value by load PIW272 it have data but not change.
so i think encoder type not match with PLC? may be PNP type?
if it can work anybody please explain about wiring connect FM350-2 and how to get counter data from encoder or recommend about encoder it work with this module
thank a lot.
PLC_ITA
Post by PLC_ITA »
i don't know the indicate encoder, but you need a positive pulse to send a FM card.
You need to configure the card ( download from siemens support the tool )
and then load the example.
use the FC into example to read the counter and appropriate job to read/write . not use the perifery to read
manual :
http://support.automation.siemens.com/W ... 4&x=19&y=4
software cofiguration tool:
flopez
Post by flopez »
With this scheme presented here, works as a PNP and ready to work with FM350
flopez
FVSOLO
Post by FVSOLO »
Thank you everyone for answer
now i send pulse to FM350-2 and can get count value but encoder still not work i think i should change to PNP-Type because i test with omron plc it's work.
Thank you a lot of all
flopez
Post by flopez »
FVSOLO wrote:now i send pulse to FM350-2 and can get count value but encoder still not work i think i should change to PNP-Type because i test with omron plc it's work.
flopez
PLC_ITA
Post by PLC_ITA »
to try purpose, connect out A into a classic digital input and check if the led blink
Sinamics
Re: [?]: connect encoder omron to FM350-2
Post by Sinamics »
Hi
I have the same problem, could someone please re-post the image above explaining how this encoder should be wired.
I have couple of rotary encoders im not able to read any values from, type:
  • 1000P/R 3 Channel 6mm (NPN)
    MUJIE M38S6-C
Im using FM350-2 counter module, connected to 315-2 CPU.
Im not able to get any count readings, using the commissioning tool in HW.
Encoder has A-B-Z and +- wires and i have connected A to A0 and B to B0 and 24v power.
FM350-2 has 24v on L+ and ground on M. There are no errors in the CPU or counter module.
I have a hunch that this encoder may not be supported by the FM350-2 module, as this one i NPN type.
Encoder datasheet.
https://drive.google.com/file/d/1mjNJpj ... sp=sharing
Could anyone please let me know if i can use this encoder with FM350-2 counter card.?
Thanks in advance.
Adrian
