hello everyone
i need crack or serial file for "s7-200 pc access" program
everyone thanks
[?]: S7-200 PC ACCESS CRACK
ilhano1978
you don't crack's need to work with Siemens PC Access: follow the next steps and you'll enjoied it.
Install PC Access demo version at this link:http://www2.sea.siemens.com/Products/Au ... ftware.htm
Install PC Access service pack 1 on tis site:
http://support.automation.siemens.com/W ... 6&x=21&y=7
Follow all the installing program instructions, of course. Now you've the PC Access sp1 integrally version; download the sp3 and install it if you want the last version full working.
You can download S7-PC Access V1.0 SP2 from Siemens Support:
http://support.automation.siemens.com/W ... d=21898252
Download place for the setup.inx file http://databridge.narod.ru/index_old.htm
[dead] :/24575901/Mi ... .0_SP2.zip
Start the Setup and go to your lokal\Temp folder, wait up the language Dialog from Setup and save the complete new folder on an other place.
Thereafter you can abort the setup.
Replace the setup.inx file with the new file and start the setup again...
