[?]: DC master 6RA70 S00 option carck
amit
Anybody have idea how to crack DC master 6RA70 S00 option ( pin) i.e. dependent on sr no of drive
Amit
Amit
phoompat
Re: [?]: DC master 6RA70 S00 option carck
Yes,I have
phoompat
read eeprom 25128 edit
add = 3ff4, 3ff5,3ff6,3ff7
00h = 00 , 00 , 00 , 00 = 0000000/3600 = 0 hr
500h = 40 , 77 , 1b , 00 = 1800000/3600 = 500 hr
1000h = 80, ee, 36, 00 = 3600000/3600 = 1000 hr
1500h = c5 , 65 , 52 , 00 = 5400005/3600 = 1500 hr
2000h = 00 , dd , 6d , 00 = 7200000/3600 = 2000 limited
sumchack
[Add 3FE1 Add 3FE0] = [add3FE3 add3FE2]+[add3FE5 add3FE4]+[add3FE7 add3FE6]+[add3FE9 add3FE8]+
[add3FEB add3FEA]+[add3FED add3FEC]+[add3FEF add3FEE]+[add3FF1 add3FF0]+
[add3FF3 add3FF2]+[addXXXX addXXXX]+[addXXXX addXXXX]+[add3FF9 add3FF8]+
[add3FFB add3FFA]+[add3FFD add3FFC]+[add3FFF add3FFE]
EXAMPLE 1
6E 00 , 3B 3C , 01 0B , 00 DD , 6D 00 , 05 00 , 02 00
006E + 3E3B + 0B01 + DD00 + 006D + 0005 + 0002 = 1271E
1 _ 271E
[Add 3FE1 Add 3FE0] = 1E27
sumchack
EXAMPLE 1
1 _ 271E
amit
Not understood properly ...Please elaboarte in detail.
Thanx
Amit
Thanx
Amit
phoompat
phoompat
defalt at 500 hr
address 3ff4 = 40
address 3ff5 = 77
address 3ff6 = 1b
address 3ff7 = 00
edit is 2000 hr
address 3ff4 = 00
address 3ff5 = dd
address 3ff6 = 6d
address 3ff7 = 00
and edit check sum by
Address 3FE1 = ??+??+??+?? (from read data)
Address 3FE0 = ??+??+??+?? (from read data)
address 3ff4 = 40
address 3ff5 = 77
address 3ff6 = 1b
address 3ff7 = 00
edit is 2000 hr
address 3ff4 = 00
address 3ff5 = dd
address 3ff6 = 6d
address 3ff7 = 00
gomoura
How do I place this reading, I have to take the eprom or is otherwise
gomoura
phoompat wrote:read eeprom 25128 edit
sumchack
EXAMPLE 1
1 _ 271E
How is this conversion?
phoompat
Need to solve the Visiting hours are 2000 hours.
because, 2000 hour => 7200000 sec =>( 00 , dd , 6d , 00 ) ==> unlock 200 hour
but, After hours and change to change sumcheck with the calculation of the reading.
sol
Take the reading from the eprom location in sum
EXAMPLE 1
[add3FE3 add3FE2] = 6E 00
[add3FE5 add3FE4] = 3B 3C
[add3FE7 add3FE6] = 01 0B
[add3FE9 add3FE8] = 00 DD
[add3FEB add3FEA] = 6D 00
[add3FED add3FEC] = 05 00
[add3FEF add3FEE] = 02 00
[add3FF1 add3FF0] = 006E
[add3FF3 add3FF2] = 006E
[addXXXX addXXXX] = 3E3B // fix value
[addXXXX addXXXX] = 0B01 // fix value
[add3FF9 add3FF8] = DD00
[add3FFB add3FFA] = 006D
[add3FFD add3FFC] = 0005
[add3FFF add3FFE] = 0002
Therefore, the values that have to put 271E
Usage save file to fix that and then be loaded into the same place.
sol
EXAMPLE 1
gomoura
good day ..
reading the EEPROM would be in direct drive, or would it take to read the external EEPROM
phoompat
eprom is not in the control card.
Remove the control card.
gomoura
Could you explain, I could not understand, then it would be right on the rack 6RA70
phoompat
gomoura
Good Morning
Could you pass this explanation to content .. I would doubt if I get online directly with the rack or the Simoreg have to get the external component to read ...
phoompat
ciwa
phoompat
angelo
it can not download nowphoompat wrote:https://rapidshare.com/files/452457144/CarkS00.rar
sinmaster12
Phoompat
Plz upload the crack file again...
amit15177
Dear Amit , do you want to dammage drive?
