[?]: How to insert SFB and SFC
Arthurious
Post by Arthurious »
hi,
how to insert SFB and SFC in your main program..
Quick info on SFB or SFC (manual or tutorial) would be appreciable..
Regards,
Contact:
Call SFBxx
Call SFCxx
what do you want?
Umencho
Post by Umencho »
You can use manual from insallation directory of Simatic. ( C:\Program Files\Siemens\Documentation\English ). Title is "STEP 7 - System and Standard Functions for S7-300 and S7-400". If you want to check which SFB or SFC supports some CPU - go online mode into progect screen, select S7 programs - Blocks and you'll see all SFC and SFB.
Or other way is to select CPU, right click with mouse go to PLC - Module information and there in one of existing tabs you'll see list with SFC and SFB...
Hope this helps.
Best regards
Arthurious
thanks a lot for info....
Regards,
