Dear alls,
I have problem with MP277, the windows CE is always hang when reboot. So it cannot works well.
I want to re-install, but I haven't software Windows CE 5.0 Build 1400 use for MP277.
Is anybody have this "warez" software in URL ?
Thank you very much for your help.
[?]: Windows CE in MP277 is CRASH
st3v3
st3v3
Re: Pls Help, my Windows CE in MP277 is CRASH
And if you have the same experience like me, please share with me, how to fix it ?
because it's already third time happen in my factory.
And the supplier didn't want to applied warranty, because it happen for three times with the same problem....
My Operating Panel room is FULL AC, with temperature arroung 20 degree celcius.
communication with S7-300 PLC using Ethernet cable,
the problem happen sometime when I upload and download using laptop, through TCP/IP (using switch with PLC)
st3v3 wrote:Dear alls,
Learn more about panels and WinCC Flexiblest3v3 wrote:Dear Sir,
My version is WinCC V6.0 SP1
CoMod wrote:Your WinCC Flexible version number ?
https://www.automation.siemens.com/micr ... ex_en.html
WinCC Flexible 2008 SP1
http://plc.net.ru/viewtopic.php?t=8650
WinCC <not Equal> WinCC Flexible !st3v3 wrote:But, the problem is on the WINDOWS CE, so I need download URL for Windows CE instead of WinCC.
http://www.automation.siemens.com/hmi/h ... /index.htm
WinCC Flexible > Transfer > OS Update (OS = Windows CE)
st3v3
Dear Sir,
thank you for your kindness to answer my question.
Yes, I've told that Windows CE (OS) can be updated from ProSave, which is Free from SIEMENS.
and it must boot from USB to loading the bootstrap.
But, currently, I cannot boot from USB, becase my engineer said, that the Panel must be setting from OS, but the condition now, I even cannot booting from my OS. It always HANG....no response.
One engineer from Hongkong told me, that is the known problem in MP277, when the program download is failed, it will erased old program, and the solution is installing MP277 again with ProSave, so the program can be downloaded again to MP277.
My question is, how can I arrange the boot priority, so It can boot from USB flash first than HDD.
Thanks in advance.
Thanks in advance.
Please show photo of your MP277 with HDDst3v3 wrote:...
http://aunz.siemens.com/NewsCentre/Prod ... MP277.aspx
No USB boot
No HDD (mechanical Hard Disk Drive)
Only 6 Mbytes of Application memory
st3v3
Sorry for miss information,
you're right. I'm not expert in technical matters.
My MP 277 is MP277 10" Key
My engineer does the service task, and I'm just help him to find information through this forum.
If MP277 cannot booting from USB,
so, how to fix my problem ?
My windows is always hang when I reboot the machine,
so it must be reinstalled by using ProSave (am I right ??)
How to do that ??
How to do that ??
http://support.automation.siemens.com/W ... n/19701610st3v3 wrote:If MP277 cannot booting from USB,
How to do that ??
You need BIOS image file for MP277The PDF document includes instructions for how to do an "Operating system update" or "Reset to factory settings" (Booting) using the ProSave software.
[dead] :/223590263/M ... _1_2_0.img
!!! when you reinstall BIOS => project in the panel will be deleted !!!
You have The Project ?
st3v3
