I have the file *.arh creat by old protool v1.x or V2.x
but i can't open it by new protool v6.x
how can i do?
thank you
[?]: HOW to open the *.arh file with new protool 6.0
It's been a while since I done this but if you chose the option
to integrate protool into S7 you cant retrieve the file directly.
You have to open protool and select for it not to be integrated into S7.
Once you do this and restart protool you should then have options
to retrieve from archive file and go from here to convert to pdb
