[?] License CFC Download Warnning?
msnqb
Post by msnqb »
Warnning wrote:The license available is not sufficient for the configured process objects (54).
Please upgrade to another license or book the process objects in programs which are no longer necessary back to the existing license.
You can continue the download process, however.
Please see the notes in the help file.
Pls help me! :!:
AS RT PO license transfered to inside PLC when download program
When you download new configuration you cal lost license inside PLC :!:
!!!! wrote: Please see the notes in the help file.
Try
SIFCYASRPX0700A
msnqb
Post by msnqb »
my problem is occured by downloading to a REAL CPU(414-3XM05-0AB0 ROM V5.2.1)first time
License "SIFCYASRPX0700A" Can not solve this problem.
PCS7 version is 7.0 sp2
Pls help me,THank U!
msnqb
Post by msnqb »
CoMod wrote:try SIFPZASRPX9999*
http://plc.net.ru/viewtopic.php?p=13428#13428
the license SIFPZASRPX9999* can not solve this problem
===== from Russian forum ========
Show your screen ^^^^
msnqb
Post by msnqb »
should not you encounter this problem?
My PCS7 version is PCS7 sp1 ro sp2 chinese.
Process Control System PCS 7 V7.0 SP1
PC Configuration and Authorization
https://support.automation.siemens.com/ ... _en-US.pdf
p.120-122
gabitzu6
CFC Problem with PO license....
Post by gabitzu6 »
In Logs windows after Chart compile is ready at Download tab I recive an error and at details i recive this text:
"More POs are needed for the program to be loaded that are currently available in the ALM.
The program is still loaded but the error state is noted.
Once the licenses have been increased, the POs marked with this error state are included in the booking during the next download.
You can find detailed information on PO licenses under
Counting and Booking PO Licenses "
What to do?!
Re: CFC Problem with PO license....
gabitzu6 wrote:What to do?!
do screencopy of PO statistic and ALM
gabitzu6
Post by gabitzu6 »
this is the logs windows :
ALM part 1:
ALM part 2:
And I want to know if this error with PO can go me at this error that apper after I try to compile CFC:
and that DB nr. is other with every compile that I do
Thanks a lot !
Try Count Relevant
SIFCYASRPX0700A
