[?]: CX-PROGRAMMER after Simatic Step7
CX-One, CX programmer, NTST, Syswin ....
alekbeck
Post by alekbeck »
I need some help with my PLC program!
I am having trouble understanding how CX-PROGRAMMER works.
All my PLC knowledge is based on Simatic Step7 and FBD programming.
I have read many guides but I still have trouble understanding the addresses.
The digital inputs address is for example
  • Step7 I 128.0 .. ,
  • Omron 00.00 – 15.15 ?
The digital output address is for example
  • Step7 Q 128.0 .. ,
  • Omron 100.00 – 115.15 ?
When programming in simatic I often use memory’s , for example M0.0.
If the value is INT or REAl I use MW1 ( M0.0 – M1.7) or MD1 (M0.0 – M3.7) .
How do I do this in CX-Programming ?
I’ve found that workbits is from 16.00 – 89.15.
Do I write W16 ?
My biggest problem is handling analog signals.
I am trying to make a program where I regulate the airflow.
In simatic I would scale the 0-10V input signal into 0-100 %.
I would then used a PID self tuner for then to unscale it back to 0-10v.
I have found the PIDAT block but I cant find any information about the parameters.
Could enyone help me with a example ?
The PLC im using is CJ1M
Re: [?]: CX-PROGRAMMER after Simatic Step7
alekbeck wrote:If the value is INT or REAl I use MW1 ( M0.0 – M1.7)
mw1(m1.0-m2.7)!!
s7 adresing is base byte,omron-word
s7=mw100(m100.0-m101.7)
omron=100(100.00-100.15)
omron adressing is all-in-one(in,out,memory=0.00-(i think)32767.00)
gigi10
Post by gigi10 »
hi alekbeck
CX-Programmer contains very poor dokumentation about instructions - on Omron pages find this manual:
W340-E1-11 (W340 is important, E means english, 11 is version)
This manual is about instructions and memory adressing in CS/CJ plc
For analog cards you need manual number W345-E1-05...
Both (all Omron's) manuals have hundred's pages... :D
enjoy
gigi10
Homeroid_BL
Programming OMRON PLC
Post by Homeroid_BL »
Plesa use a proper OPERATING MANUAL adn PROGRAMMING of the Omron PLC you want to use. You will fnd a detailed explanation there. Easy! (not like a Siemens, ugh!)
