[?]: migrate from OP17 to WinCC Flexible PC Runtime
cemara
Contact:
Post by cemara »
I have OP17. it is damage now.
i am planning to use winCC flexible RT with PC.
i got an old file with extension pda, par, rpa,arh, mdx, clip organizer media package. i do not know what it is.
when i try to open *.pda file using Protool V6.0 SP2.
The first error message is as follows
Error wrote:"Your project was created ith ProTool V1.x. In Protool V2.0 and later, projects are stored in a single file. The directory having the project name is no longer required"
When i acknowledge this the following popup box appears
Error wrote:"The required Device type "" is not supported by the ProTool version installed. Check the entries in the C:\Siemens\protool\protool.ini file"
i guess this files were the original OP17 one. my problem is how i am going to migrate it to winCC flexible.
Please help. thank you
