Dear Friends,
This is the first time I use Sinaut tool
I have some questions about the Sinaut ST7 system:
1. How to communicate between 2 CPUs ( 313C+Tim43-----WAN------Tim33+314C) in Sinaut system(configured by "ST7 configuration" and Step7) which don't use ST7cc? Could you show me some methods?
2. If WAN networks is dial-up networks and the distance between 2 CPUs about 15km, Which parameter of WAN I should set ?
3.Can use the function Sinaut-Routing in above scence?
We are look forward to hearing from you!
Thanks in advance!
[?+]: Communicate 2 CPUs in the Sinaut ST7 System
Re: [?]: Communicate 2 CPUs in the Sinaut ST7 System
Done!taday wrote:Dear Friends,
Thanks in advance!
Thanks !
