[?]: Read a HART level instrument with 6ES7 331 7TB00 card
PLC_ITA
Post by PLC_ITA »
Hi friend, i need to read a level instrument whith 6es7 331 7tb00 card.
i need to read a analog value throught 4-20 Ma and another analog value via HART but i dont know how to do for the hart channel
I use a step 7 v5.4 ( not pcs7 )
thank you in advance
dsekulic
Post by dsekulic »
Look here and link on Entry ID: 1096709 (link is on the bottom of page)
http://support.automation.siemens.com/W ... n/19141245
Chapter 4 http://support.automation.siemens.com/W ... en/1096709
regards
PLC_ITA
Post by PLC_ITA »
Thank you Dsekulic for your help. I have rread the manual but i don't understand how and where i can write a command.
For example if i want to send a command #10 ( see page 195 ) where i write this parameter and where i read the response ?
thank you
dsekulic
Post by dsekulic »
try this manual. There you have example.
http://support.automation.siemens.com/W ... nload=true
regards
