Good day, is there a way to communicate s7-200 to intouch using ethernet? If yes what other software do i need like (PC Access ? ) or no need just the cp. And if yes also does this soppurt cross connection of cable without using ethernet switch.
Thank you very much in advance.
Warm regards,
REy
[?]: S7-200 ethernet communication to Wonderware
reymond_craig
bunglehead
Hello Ray,
Another decision is to use "good old" DASSIDIRECT Server (of course if you have CP). Maybe your favorite.
Look at http://61.37.246.137/TECH/html/t002006.htm or
http://fa.sammicomputer.co.kr/TECH/html/t002006.htm
Hope this will helps.
regards
regards
