[?]: Rockwell activation 2009
Tcp
Post by Tcp »
Is there someone have 2009 rockwell activation?
neuhauser1234
Post by neuhauser1234 »
I'm afraid that's going to be tough.
This year Rockwell is moving all of it's new software to FactoryTalk Activation.
code is sent to the owner of the software that is entered in the activation process.
At this time there is two options: activate using the mac address of a lan card or the harddrive.
A code is generated and entered on Rockwell's web site then a license is emailed back.
If the activation is generated from the lan card you have a chance of using a virtual loopback port to duplicate the mac.
If it uses the hard drive I'm afraid you're out of luck.
The actual hard drive factory serial number is used- not the partition serial.
I haven't found a way to make virtual hard drive that the serial can be changed yet.
If you do find a way please share it. I'm sure everyone here would like to know.
