How to Unlock Cx programmer FB password
CX-One, CX programmer, NTST, Syswin ....
andreyit
Re: How to Unlock Cx programmer FB password
Post by andreyit »
UTE87
126
hvsantos
Post by hvsantos »
Please, can you hepl me, crack me task read protection and funtion block password.
Thank you
https://drive.google.com/file/d/18DwSEo ... sp=sharing
defo2004
Post by defo2004 »
Olá! Seu programa e blocos de funções são muito complexos para trabalhar na definição de senhas ... Piada você carregou um projeto vazio-zero. Veja o que você colocou na nuvem... (no)
hvsantos
Post by hvsantos »
I'm sorry, but I didn't realize that I had saved the program empty.
When I connected online as a PLC, it was giving me an error UM and saying that it couldn't be written over.
I tried to save it anyway, but it didn't look good.
I'll try again next time.
Supremacy1989
Post by Supremacy1989 »
Perfect, Many Thanks.
Got another file that requires unlocking as well. Some have extra passwords on top of those.
Thanks in advance.
EDIT: Looks like I've figured out how to obtain the passwords myself
mosayeb
Post by mosayeb »
Please, can you help me, crack me task read protection
Thank you
https://drive.google.com/file/d/18yX87F ... drive_link
defo2004
Post by defo2004 »
Hi! Look at the private messages.
Horatiu89
Post by Horatiu89 »
Hello, can you help me to crack this file? We work at a water factory and our machine gone crazy and we need to find the problem and we can connect to it. Thank you very much.
https://drive.google.com/drive/folders/ ... drive_link
defo2004
Post by defo2004 »
Hi!
Below in the text I give an example of the concept of emptiness, well, almost the same as in your .cxp file...
Properties of emptiness.
How can the properties of "emptiness" be determined? After all, at first glance, it is invisible, inaudible, not measurable, does not interact with anything, etc. With the help of intermediary objects, toolkit objects containing, among other things, the properties of "void" objects. If we use our mathematical model in which object A is a function of its properties a1,a3,a5,a8 or A = f (a1,a3,a5,a8) , B=f (b1,b3,b7,b9,b12 ) , then the toolkit object C will have, for example, properties commensurate with both the properties of object A and the properties of object B or C = f (c5,c8,c7,c9,c12).
In physics, instrumentation objects (intermediaries) are all kinds of measuring devices (voltmeters, spectrometers, thermometers, Geiger counters, etc.) Because not so long ago, for humanity, there were "voids": electromagnetic field and charged particles, radiation, streams of elementary particles and radiation, atomicity, valence, and many other things. In human communication, intermediaries are, for example, foreign translators. Narrow–profile professionals are also intermediaries between ordinary people who want to learn more about their profession. Even an excavator can be considered as an intermediary object between a person and the objects of nature that he changes. However, these intermediaries are not related to the "void" (ev)
hasanpoor
Post by hasanpoor »
hi
Thankyou ,very very good
defo2004
Post by defo2004 »
Hi! Look at the private messages. Good luck! (thnx)
oedschnoed
Post by oedschnoed »
defo2004
Post by defo2004 »
Upload your file so that it is available for everyone to download and you will be happy... (tyou)
oedschnoed
oops, i forgot, now for everyone
andreyit
Post by andreyit »
oedschnoed wrote: Fri Feb 28, 2025 10:09 am I also need the unlock password
https://drive.google.com/file/d/13Ccp-w ... sp=sharing
Edwin72
ksvitae
Post by ksvitae »
Hello everyone,
I have an OMRON CP1L-M60DR-A PLC protected with:
AR99.00 = 1
AR99.01 = 1
AR99.02 = 1
AR99.03 = 1
AR99.04 = 1
THEREFORE : AR99 = 001F
The last bit AR99.04 is not documented in the Omron PDFs
and with this protection, the program area is read- and write-protected.
I even tried with applications that find passwords, but it doesn't work.
Please, can someone help me?
defo2004
Post by defo2004 »
ksvitae wrote: Wed Mar 19, 2025 1:24 pm Hello everyone,
AR99.00 = 1
AR99.01 = 1
AR99.02 = 1
AR99.03 = 1
AR99.04 = 1
Hi!
Your controller is protected to the maximum, all protections are enabled, for reading, tasks, copying to the card, overwriting the program, A99 = F, and enhanced A99 protection is also enabled.03 = 1 Total : A99 = 001F All known programs cannot bypass enhanced protection , other methods and tools are needed here ... (boom)
I can sympathize with you.. (thnx)
ksvitae
Post by ksvitae »
defo2004 wrote: Thu Mar 20, 2025 7:42 am
AR99.00 = 1
AR99.01 = 1
AR99.02 = 1
AR99.03 = 1
AR99.04 = 1
Hi!
Yes, of course we can sympathize.
Enhanced A99 protection is also activated. You mean: ar99.04 = 1.
defo2004
Post by defo2004 »
ksvitae wrote: Thu Mar 20, 2025 10:13 am Yes, of course we can sympathize.
Yes, that's right, this bit indicates that the enhanced protection of the controller is activated. (h)
ksvitae
Post by ksvitae »
defo2004 wrote: Thu Mar 20, 2025 12:32 pm Yes, that's right, this bit indicates that the enhanced protection of the controller is activated. (h)
how is this advanced protection activated ar99.04 = 1 and is there a way to deactivate it
defo2004
Post by defo2004 »
ksvitae wrote: Thu Mar 20, 2025 12:36 pm how is this advanced protection activated ar99.04 = 1 and is there a way to deactivate it
If the program is loaded into a PLC with such protection, then you can remove the enhanced protection only by unloading the program from the PLC and removing the specified label through the CX-Programmer, PLC properties, protection, "Enhanced password protection", load it back into the PLC without this option. But to do this, you need to know the password from the program to access it. (no)
Well, you also need the programmer's version to be more or less new to support this option.
defo2004
Post by defo2004 »
ALL
bjyou9999
Post by bjyou9999 »
defo2004
Post by defo2004 »
Перезагрузите ваш файл на доступный сервис , облако...
alexcibs
Post by alexcibs »
Hello, i have a program with some FB locked, it's possible to recover the password? Thanks.
defo2004
Post by defo2004 »
alexcibs wrote: Wed Mar 26, 2025 10:31 am Hello, i have a program with some FB locked, it's possible to recover the password? Thanks.
Yes
alexcibs
Post by alexcibs »
defo2004 wrote: Wed Mar 26, 2025 11:30 am
Yes
ok, how i can do ?
i must send you the program?
defo2004
Post by defo2004 »
alexcibs wrote: Wed Mar 26, 2025 12:55 pm
Yes
ok, how i can do ?
You can upload it to an accessible cloud or file storage, or you can send it to me by email...
alexcibs
Post by alexcibs »
This is the project, if i remember correctly, the password was the same for all the fb
https://drive.google.com/drive/folders/ ... sp=sharing
defo2004
Post by defo2004 »
alexcibs wrote: Wed Mar 26, 2025 2:51 pm This is the project, if i remember correctly, the password was the same for all the fb
For FB Misuratore Portata 25151617
For the rest FB davide10
Good luck (thnx)
alexcibs
Post by alexcibs »
Great!!
Thanks a lot
lostfox
Post by lostfox »
Hello everyone, I really need help in unlocking the functional blocks.
I tried it myself, but nothing worked.
bjyou9999
Post by bjyou9999 »
pinosc
lostfox
Post by lostfox »
Thank you very much!
trungtruc
Post by trungtruc »
Hi, I have a program which has protected function blocks. Can anyone help me to unlock it ? https://drive.google.com/file/d/1Foihss ... sp=sharing
andreyit
Post by andreyit »
jpcrj
trungtruc
Post by trungtruc »
Thank you so much!!!
kalex
Post by kalex »
Hello. Can you help me unlock the function block? https://drive.google.com/drive/folders/1IFZjhWB2-O65SKIYJO19MJBitILHrtVA
defo2004
Post by defo2004 »
Hi! Check your personal email. In the future, you can attach the entire program to my email if you don't want to post it here. (thnx)
Madu
Post by Madu »
good morning
i lost the password of the function blocks can you help me
thanks
https://drive.google.com/file/d/1Bxi10K ... sp=sharing
bjyou9999
Post by bjyou9999 »
kalex wrote: Sat May 10, 2025 11:53 pm Hello. Can you help me unlock the function block? https://drive.google.com/drive/folders/1IFZjhWB2-O65SKIYJO19MJBitILHrtVA
OMRON PLC MODEL?
defo2004
Post by defo2004 »
Madu wrote: Tue May 27, 2025 10:05 am good morning
thanks
Hi!
Password FB int306
hanzelem54
Post by hanzelem54 »
Thank you very much for your interest, it worked. Thanks to you, I feel lucky.
defo2004
Post by defo2004 »
hanzelem54 wrote: Fri Aug 01, 2025 10:00 am Hello,
I hope you're doing well. I would like to kindly ask for your assistance in retrieving or unlocking the passwords of certain function blocks. Could you please help me with this process?
Thank you in advance for your support.
Best regards,
https://drive.google.com/file/d/1Gs3pQB ... sp=sharing
Merhaba!
Özel mesajlara bak. (thnx)
aymanefar
Post by aymanefar »
https://drive.google.com/file/d/1JYvFn1UazoLmt87kTv9AO-BCHZs7yZ-R/view
virubha12
Post by virubha12 »
https://drive.google.com/file/d/1HH6E_t ... p=drivesdk
Task Passward And FB Passward
Thanks Anvance..
pawel_1980
Post by pawel_1980 »
Hello, I have an Omron CJ2M controller. It has a locked UM. Does anyone have a program to read the password?
A99.4 is 0. A99.0 is 1
aymanefar
Post by aymanefar »
the link does not open
npt1612
Post by npt1612 »
Could you help me get the password for the attached file at the link below?
Thank you.
https://drive.google.com/file/d/1NHOHj0 ... sp=sharing
marpione
Post by marpione »
Hi.
Password:
hxpcz
hxpcjl
