How to Unlock Cx programmer FB password
Re: How to Unlock Cx programmer FB password
570406
120569
120569
Good day,
Require assistance with obtaining access to some function blocks as per linked file.
Curious as to the process of decoding the password as may have many more passwords to crack in the future.
https://drive.google.com/file/d/1Z-_xpJ ... sp=sharing
Many Thanks
Many Thanks
Please, can you hepl me, crack me task read protection and funtion block password.
https://drive.google.com/file/d/18DwSEo ... sp=sharing
Olá! Seu programa e blocos de funções são muito complexos para trabalhar na definição de senhas ... Piada você carregou um projeto vazio-zero. Veja o que você colocou na nuvem...
I'm sorry, but I didn't realize that I had saved the program empty.
When I connected online as a PLC, it was giving me an error UM and saying that it couldn't be written over.
I tried to save it anyway, but it didn't look good.
I'll try again next time.
Perfect, Many Thanks.
Got another file that requires unlocking as well. Some have extra passwords on top of those.
Thanks in advance.
EDIT: Looks like I've figured out how to obtain the passwords myself
Thanks in advance.
Please, can you help me, crack me task read protection
https://drive.google.com/file/d/18yX87F ... drive_link
Hi! Look at the private messages.
Hello, can you help me to crack this file? We work at a water factory and our machine gone crazy and we need to find the problem and we can connect to it. Thank you very much.
https://drive.google.com/drive/folders/ ... drive_link
Hi!
Below in the text I give an example of the concept of emptiness, well, almost the same as in your .cxp file...
Properties of emptiness.
How can the properties of "emptiness" be determined? After all, at first glance, it is invisible, inaudible, not measurable, does not interact with anything, etc. With the help of intermediary objects, toolkit objects containing, among other things, the properties of "void" objects. If we use our mathematical model in which object A is a function of its properties a1,a3,a5,a8 or A = f (a1,a3,a5,a8) , B=f (b1,b3,b7,b9,b12 ) , then the toolkit object C will have, for example, properties commensurate with both the properties of object A and the properties of object B or C = f (c5,c8,c7,c9,c12).
In physics, instrumentation objects (intermediaries) are all kinds of measuring devices (voltmeters, spectrometers, thermometers, Geiger counters, etc.) Because not so long ago, for humanity, there were "voids": electromagnetic field and charged particles, radiation, streams of elementary particles and radiation, atomicity, valence, and many other things. In human communication, intermediaries are, for example, foreign translators. Narrow–profile professionals are also intermediaries between ordinary people who want to learn more about their profession. Even an excavator can be considered as an intermediary object between a person and the objects of nature that he changes. However, these intermediaries are not related to the "void"
hi
Thankyou ,very very good
Hi! Look at the private messages. Good luck!
Upload your file so that it is available for everyone to download and you will be happy...
oops, i forgot, now for everyone
Edwin72oedschnoed wrote: Fri Feb 28, 2025 10:09 am I also need the unlock password
https://drive.google.com/file/d/13Ccp-w ... sp=sharing
Hello everyone,
I have an OMRON CP1L-M60DR-A PLC protected with:
AR99.00 = 1
AR99.01 = 1
AR99.02 = 1
AR99.03 = 1
AR99.04 = 1
THEREFORE : AR99 = 001F
The last bit AR99.04 is not documented in the Omron PDFs
and with this protection, the program area is read- and write-protected.
I even tried with applications that find passwords, but it doesn't work.
Please, can someone help me?
AR99.00 = 1
AR99.01 = 1
AR99.02 = 1
AR99.03 = 1
AR99.04 = 1
Hi!ksvitae wrote: Wed Mar 19, 2025 1:24 pm Hello everyone,
AR99.00 = 1
AR99.01 = 1
AR99.02 = 1
AR99.03 = 1
AR99.04 = 1
Your controller is protected to the maximum, all protections are enabled, for reading, tasks, copying to the card, overwriting the program, A99 = F, and enhanced A99 protection is also enabled.03 = 1 Total : A99 = 001F All known programs cannot bypass enhanced protection , other methods and tools are needed here ...
I can sympathize with you..
Yes, of course we can sympathize.defo2004 wrote: Thu Mar 20, 2025 7:42 amHi!ksvitae wrote: Wed Mar 19, 2025 1:24 pm Hello everyone,
AR99.00 = 1
AR99.01 = 1
AR99.02 = 1
AR99.03 = 1
AR99.04 = 1
Your controller is protected to the maximum, all protections are enabled, for reading, tasks, copying to the card, overwriting the program, A99 = F, and enhanced A99 protection is also enabled.03 = 1 Total : A99 = 001F All known programs cannot bypass enhanced protection , other methods and tools are needed here ...![]()
I can sympathize with you..![]()
Enhanced A99 protection is also activated. You mean: ar99.04 = 1.
Yes, that's right, this bit indicates that the enhanced protection of the controller is activated.ksvitae wrote: Thu Mar 20, 2025 10:13 am Yes, of course we can sympathize.
how is this advanced protection activated ar99.04 = 1 and is there a way to deactivate itdefo2004 wrote: Thu Mar 20, 2025 12:32 pm Yes, that's right, this bit indicates that the enhanced protection of the controller is activated.![]()
If the program is loaded into a PLC with such protection, then you can remove the enhanced protection only by unloading the program from the PLC and removing the specified label through the CX-Programmer, PLC properties, protection, "Enhanced password protection", load it back into the PLC without this option. But to do this, you need to know the password from the program to access it.ksvitae wrote: Thu Mar 20, 2025 12:36 pm how is this advanced protection activated ar99.04 = 1 and is there a way to deactivate it
Well, you also need the programmer's version to be more or less new to support this option.
Перезагрузите ваш файл на доступный сервис , облако...
Hello, i have a program with some FB locked, it's possible to recover the password? Thanks.
Yesalexcibs wrote: Wed Mar 26, 2025 10:31 am Hello, i have a program with some FB locked, it's possible to recover the password? Thanks.
This is the project, if i remember correctly, the password was the same for all the fb
For FB Misuratore Portata 25151617alexcibs wrote: Wed Mar 26, 2025 2:51 pm This is the project, if i remember correctly, the password was the same for all the fb
For the rest FB davide10
Good luck
Great!!
Thanks a lot
Thanks a lot
Hello everyone, I really need help in unlocking the functional blocks.
I tried it myself, but nothing worked.
Thank you very much!
Hi, I have a program which has protected function blocks. Can anyone help me to unlock it ? https://drive.google.com/file/d/1Foihss ... sp=sharing
Thank you so much!!!
Hello. Can you help me unlock the function block? https://drive.google.com/drive/folders/1IFZjhWB2-O65SKIYJO19MJBitILHrtVA
Hi! Check your personal email. In the future, you can attach the entire program to my email if you don't want to post it here.
good morning
i lost the password of the function blocks can you help me
https://drive.google.com/file/d/1Bxi10K ... sp=sharing
OMRON PLC MODEL?kalex wrote: Sat May 10, 2025 11:53 pm Hello. Can you help me unlock the function block? https://drive.google.com/drive/folders/1IFZjhWB2-O65SKIYJO19MJBitILHrtVA
Hi!Madu wrote: Tue May 27, 2025 10:05 am good morning
Password FB int306
