Eplan P8 2.8/2.9 + personal keygen
Тools, Elcad, Eplan, ...
thanh3386
Re: Eplan P8 2.8/2.9 + personal keygen
Post by thanh3386 »
(sos) Please reup link Eplan 2025. Thanks (tyou) (tyou) (tyou)
aacoa666
Post by aacoa666 »
Donau
Post by Donau »
Can someone re-record and upload the video in a higher quality.
It is sometimes hard to figure out what the person is doing.
https://www.bilibili.com/video/BV1rBCNY ... 1a4a98591
wconan100
Post by wconan100 »
thanh3386
Post by thanh3386 »
tektek
Post by tektek »
I downloaded it again and now it works for me. Thank you so much !!!
I have managed to change the language of Electric and Propanel, but can the language of the rest be changed? Could those applications (cable, fluid, ...) be reinstalled without losing the license?
aacoa666
Post by aacoa666 »
try it, u cant do something wrong (pgood)
But I think its much easier to use the vm as license server and work on your host pc :)
leonardo57
Post by leonardo57 »
Patrikrou wrote: Sun Feb 16, 2025 1:46 pm follow the installation instructions up to minute 12 of the video in the link below. (after the 12th minute I didn't really understand what he was doing)
https://www.bilibili.com/video/BV1rBCNY ... 303bcedd1f
you can directly use eplan 2025 (in Chinese) from the virtual machine, without following the instructions in the video.
1. If you will not use eplan 2025 from the virtual machine, you must install on windows any version of eplan p8 (2022, 2023, 2024, 2025) without crack.
2. follow the instructions in the video to access the license server.
3. open eplan (any version), the "license activation" window will appear, select "connect to license manager"
4. enter the ip address of the virtual machine, then connect to the server with the connection data set to "point 1".
I hope I can help you with this little tutorial (tyou)
I think the third step is to run the virtual machine on another PC within the same local network, that way you don't have to have the virtual machine running on the same PC where you use Eplan
Also, the virtual machine only uses the ELM Configurator and EPLAN Smart Production, so it requires less resources.
Thanks for yor tutorial!
Donau
Post by Donau »
I keep getting the MAX19.42 error when connecting a native machine to the VM.
I have done all the steps in the video up to 14 minutes.
I'm sure my username and password are ok.
I can ping the VM, and the firewall is off.
Anyone able to help me out further?
Update: Got it running after reinstalling the client on the native machine.
h4rdw4re
Post by h4rdw4re »
For2024 wrote: Fri Feb 21, 2025 3:19 pm Go to the Programs installation menu on the virtual machine, find the EPLAN Electric 2025 program, then click Modify. In the dropdown installer menu, you can add or remove languages and set the default language for the interface. Click OK, install, and restart virtual machine. Done.
How did you manage that?
Setup ask for EPLAN Platform 2025.msi file which is not available as it is on shared drive (\\vmware-host\Shared Folders\EPLAN\EPLAN Setup\EPLAN_2025\Platform\).
Can anyone share Eplan 2025 setup, as all links are dead.
Or can someone share EPLAN Gui en-US 2024.exe from setup?
Thanks.
leonardo57
You need to download the program installers from this link.
https://drive.google.com/drive/folders/17vgR1EtBRfE30AwMWJVameDiW8GOhy8e
Then when it asks you for them during the installation, you select them from your shared folder with the VM or you can copy them directly into it.
Then to change the language inside the program I recommend you use Google Translator on your cell phone to understand the program menus.
h4rdw4re
Post by h4rdw4re »
Thanks.
I will download as soon as the quota allow it.
Right now to many parallel downloads.
Update:
Done. Thank you mate.
It works perfectly. All in English now and updated to latest version.
Best regards.
xiaxiang
Post by xiaxiang »
Can you post two lservrc files here? Just Baidu drive,many thanks.
dgumal_
Post by dgumal_ »
Hello everyone.
Who have EPLAN Smart Production Collection 2025, please share.
zens
Post by zens »
In the video clip from the web address https://www.bilibili.com/video/BV1rBCNY ... f1a4a98591, the final step shows permanent licensing without the need for a VM, by dragging the license from the VM to the computer. How was this done, does anyone know? In the License manager, 'liqb.us.kg' is entered, presumably the name of the server, and after that, a permanent license is obtained. How?"
gino_007
Post by gino_007 »
[b[/b]
Yes, it works, I entered the settings up to minute 12. (oo) (suc)
wconan100
Post by wconan100 »
Alex Pro
Post by Alex Pro »
НОВОЕ ЛЕКАРСТВО!! А точнее не лекарcтво, а полноценный сервер лицензий для eplan 2,0-2025 на Виртуальной машине VMWare на локализованной русской Винде.
NEW CURE!! Or rather, not a medicine, but a full-fledged license server for eplan 2.0-2025 on a VMWare Virtual Machine on localized Russian Windows.
https://rutracker.org/forum/viewtopic.php?t=6656751 (suc) (suc) (suc)
igbt
Post by igbt »
Alex Pro wrote: Wed Mar 05, 2025 1:08 pm ... сервер лицензий для eplan 2,9-2025 на Виртуальной машине VMWare...
Великолепно! Ждём окончания модерации раздачи. А можно ли сконвертировать образ в виндовый хайперВ?
Link
Forum Community
Forum Community
Eplan 2025 + keygen server
Post by Link »
(mirr) https://disk.yandex.ru/d/ruYZAnnzOggaOw
Eplan 2025 + keygen server from https://rutracker.org/forum/viewtopic.php?p=87493290#87493290
Russian
Сервер лицензий EPLAN 2,9-2025 (Виртуальная машина > VMWare 17,5)
Год/Дата Выпуска: 2025
Версия: 2025
Разработчик: ChinaHacker
Сайт разработчика: нет
Разрядность: 64bit
Язык интерфейса: Русский
Таблэтка: не требуется
Реклама: отсутствует
Системные требования:
Window 10 и выше.
Описание: Виртуальная машина - Сервер лицензий EPLAN 2,9-2025 на VMWare версии 17,5 или выше
Новое "лекарство", а точнее не лекарство, а реальный сервер лицензий на виртуальной машине для Eplan от v2.9 до 2025, без "бубна" и тормозов в работе.
Следуйте указаниям с скриншотах.
Нужно запустить VMware, открыть там ВМ.
ВМ сервера запускать только через "I MOVED", иначе сломаете машину!
Выяснить IP адрес виртуальной машины.
Определение IP-адреса виртуальной машины (сервера).
1 Откройте командную строку сервере. В Windows нажать Win + R, ввести "cmd" и нажать Enter.
2. В командной строке введите команду "ipconfig" и нажмите Enter.
3. Найдите строку "IPv4-адрес" или "IPv4 Address". Рядом с этой строкой будет указан IP-адрес ВМ. Например, "192.168.1.100", который нужно внести в адрес менеджера лицензий при первом запуске ePlan. и ВуАля...
Доп. информация: Windows key:eplan
User licence manager: xx\EPLAN
Pass: 5379
VMWare можно взять тут:https://rutracker.org/forum/viewtopic.php?t=6492639
Для запуска ВМ в фоновом режиме создать батик с текстом:
"C:\Program Files (x86)\VMware\VMware Workstation\vmrun.exe" start "C:\VMware Workstation\SERVER\EPLAN 2025.vmx" nogui
путь в ВМ прописать свой и закинуть в startup.
Никакие настройки менять не рекомендуется, рискуете "сломать" сервер лицензий eplan!
English
EPLAN License Server 2.9-2025 (Virtual Machine > VMWare 17.5)
Year/Release Date: 2025
Version: 2025
Developer: ChinaHacker
Developer's website: no
Bit depth: 64bit
Interface language: Russian
Tablet: not required
Advertising: none
System requirements:
Window 10 and above.
Description: Virtual Machine - EPLAN License Server 2.9-2025 on VMWare version 17.5 or above
A new "cure", or rather not a cure, but a real license server on a virtual machine for Eplan from v2.9 to 2025, without "tambourine" and brakes in operation.
Follow the instructions in the screenshots.
You need to run VMware, open the VM there.
Run the server VM only via "I MOVED", otherwise you will break the machine!
Find out the IP address of the virtual machine.
Determining the IP address of the virtual machine (server).
1 Open the command line on the server. In Windows, press Win + R, enter "cmd" and press Enter.
2. In the command line, enter the command "ipconfig" and press Enter.
3. Find the line "IPv4 address" or "IPv4 Address". The IP address of the VM will be indicated next to this line. For example, "192.168.1.100", which must be entered in the license manager address when you first start ePlan. and Voila...
Additional. information: Windows key:eplan
Pass: 5379
VMWare can be taken here: https://rutracker.org/forum/viewtopic.php?t=6492639
To start VM in the background, create a batik with the text:
write your own path to VM and throw it into startup.
It is not recommended to change any settings, you risk "breaking" the eplan license server!
h4rdw4re
Post by h4rdw4re »
According to the disk size and language visible on photos (Chinese), could it be possible that this one is only stripped version, i.e. removed ePlan and all components except license of complete ePlan2025 already posted on forum?
Someone already posted that previous disk can be used as license server also.
ragundo
Re: Eplan 2025 + keygen server
Post by ragundo »
What's the password for login in the VM?
img https://u.pcloud.link/publink/show?code ... BLB5WRmmD7
I can't continue the process because I can't login!!!
EDIT: I found the solution. For non russian people, change the language input method to english.
The password is eplan
Greetings
Klamsi
Post by Klamsi »
go in the lower right corner and change language to english, then you can use the password eplan
Luka0704
Post by Luka0704 »
Hello
Few things that I did.
I use VMware Workstation 17 Player program.
I use two VM. One as SERVER (downloaded from this page) and one in which I installed EPLAN 2025.
In VMWARE Player adapter settings I put both VM on LAN Segment so that they only see each other but can't see internet.
(Little paranoid about EPLAN connecting to net - :haha: )
I put static IP address on both of them so they are in the same range.
For example:
SERVER VM: 169.254.79.107
EPLAN VM: 169.254.79.108
SERVER IP address I found through "cmd prompt ->ipconfig".
In both VM I disabled Firewall & Network protection on all 3 networks (Domain, Private, Public).
Maybe it is only one needed but I didn't want to search which one.
Microsoft Defender Firewall -> off
This last part was used as I got message.
https://fastpic.org/view/124/2025/0308/ ... g.html?r=1
This is medicine.
Everything else I did as in instruction file.
sheenx
Post by sheenx »
check your host PC's service, make sure "VMware DHCP service" & "VMware NAT service" is running.
mayers21
Post by mayers21 »
Pass: 5379
Is not working?
Anyone having same issue?
bencardride
Post by bencardride »
Kann mir jemand Helfen????
Zugriff verweigert bei dem Lizenz Manager von EPLAN 2025 VMware!!!!
Firewall deaktiviert und Windows Defender auch
IP Adresse Eplan2025 VMware: 192.168.128.129
Benutzer: EPLAN2025_20241\EPLAN2025
PW: eplan2025
LG Paule
mayers21
Post by mayers21 »
Have you tried
Pass: 5379
engpob
Post by engpob »
Hi, does anyone have original distributions of EPLAN 2023 + Electic + ProPanel + etc. + updates?
leonardo57
Hi, can someone reupload the folowing pan.baidu links?
EPLAN_LPM_2024.zip
EPLAN_LPM_2025.zip
New metod to run DataPortal,
https://www.bilibili.com/video/BV1chA1ecEkg/
Thanks.
eplanuser006
Post by eplanuser006 »
I was able to solve it by installing the englisch version of eplan in the chinese vmware image.
When running eplan i was able to change the language.
calu1100
Post by calu1100 »
Hello, have you found a solution to your problem?
Have the same problem.
System Windows 11 Pro 24H2.
And is it normal for my virus scanner to display a virus in the vcrunntime140.dll ?
onos217
Post by onos217 »
I downloaded EPLAN 2022. I Installed all the installables and It worked for a week. Today I made an attempt to use it and I got the below statement:
"The period during which you could start EPLAN without ePULSE sign-in has expired. Restart EPLAN and sign-in to ePULSE"
Please someone should point me to how I could bypass the ePULSE sign-in. Thank you as I anticipate responses.
eplan 2,0-2025 license has a time limit to 2025-04-05
Alex Pro wrote: Wed Mar 05, 2025 1:08 pm НОВОЕ ЛЕКАРСТВО!! А точнее не лекарcтво, а полноценный сервер лицензий для eplan 2,0-2025 на Виртуальной машине VMWare на локализованной русской Винде.
(boom) eplan 2,0-2025 license has a time limit to 2025-04-05...
По умолчанию в настройках стоит ограничение
прав пользователя 1 месяц.
Для продолжения работы после 5 апреля надо задать
"Срок действия не ограничен"
By default, the settings limit user rights to 1 month.
To continue working after April 5, you need to set
"Validity is unlimited"
我的也是,我将许可证服务器系统时间修改为20250405之前就可以了,也许许可证是有时间限制的。
Mine is the same, I changed the license server system time to before 2025-04-05 and it worked. Maybe the license has a time limit。
У меня то же самое, я изменил системное время сервера лицензий на время до 2025-04-05, и это сработало. Возможно, лицензия имеет ограничение по времени。
(h)
我的建议是在目前没有更好的解决方案情况下将许可证服务器系统时间到尽可能向前更改(我目前试的时间为2024年12月下旬),这样一年只需更改3次即可。
My suggestion is to change the license server system time as far forward as possible (I am currently trying to change it to late December 2024) in the absence of a better solution, so that it only needs to be changed 3 times a year.
Я предлагаю изменить системное время сервера лицензий как можно дальше вперед (сейчас я пытаюсь изменить его на конец декабря 2024 года) в отсутствие лучшего решения, чтобы его нужно было менять только три раза в год
------- "Password does expire"-----------
In the "Local Users" settings for the EPLAN user, remove "Requirement to change password at next login" and set "Password does not expire"
Надо в настройках "Локальные пользователи" для пользователя EPLAN снять "Требование смены пароля при следующем входе в систему" и поставить "Срок действия пароля не ограничен"
(usearch) https://rutracker.org/forum/viewtopic.php?t=6656751
elmum
Post by elmum »
Could someone make the virtual machine available for download on a popular filehoster?
twatson
Post by twatson »
There is no time limit, and Eplan 2025 can still be used normally today.
MKAutomation
Post by MKAutomation »
Help Please,
i Have Problem
I have installed P8 2.9 and 2023 all works with crack but afther a long time not work
it where error [210092] The given license code is invalid. Hence, it could not be added to the "no-net" license server.
THX
sheenx
Post by sheenx »
Have you updated the windows system to 24H2? The crack not compatible with 24H2.
fulanito
Post by fulanito »
I have problems with my installation. I follow all the steps and when I try to execute the program an error occurs:
"...an error occurred while reading the license error 210092 the given license code is invalid. ..."
I got the program here:
https://filecr.com/windows/eplan-electric-p8/
Why this happens? Is the program files outdated or is the patch?
azad2501
Post by azad2501 »
I have installed the ePLAN P8 2.9 2024.3.21408 version and the software works.
But 5 or 10 minutes after doing something say creating a macro or inserting a new device a problem occurs. (boom)
suppose I have inserted a drive for SEW. Now I want to change its DT and other data.
When I go the property option and I change the name from say P? to P5 or P10 or anything
and click on the Apply button, the whole window closes without taking any change from my command.
once this problem occurs, I have to close the whole ePLAN program and restart it.
Works fine for the next 5 or 10 minutes and again the same problem occurs.
any help or suggestions to get rid of this problem will be appreciated. thank you
onos217
Post by onos217 »
Hi guys. Please in the virtual Machine folder on google drive, which of the file do i download?
zesava
Post by zesava »
Does anyone know how to run this VM on Proxmox?
I used Acronis True Image to move the VM from VMware to Proxmox, and it is running fine.
However, when I launch the ELM Configurator, I get this error
mioduz
Post by mioduz »
What is everyones experience with eplan enforcing this crack if you allow it to go online to download from data portal????
Any advice?
gino_007
Post by gino_007 »
leonardo57 wrote: Thu Mar 27, 2025 6:37 pm New metod to run DataPortal,
I can't download it (EPLAN_LPM), it's on a Chinese website and that's not so easy if you're from Europe.
Donau
Post by Donau »
Hi All,
I am looking for the setup files of Eplan5.
Does someone have this available?
Thank you
basukesu
Post by basukesu »
gino_007 wrote: Mon May 26, 2025 5:43 am
I've uploaded both LPM files to google drive to make it easier for others to get them.
:D
https://drive.google.com/drive/folders/ ... sp=sharing
YDC001
Post by YDC001 »
Hello, is it really not possible to have a stand alone crack of EPLAN 2025? Or the possibility to setup our own Virtual License Server and not the use of the CH or RU ones?
aacoa666
Post by aacoa666 »
yes, it is possible if you have an cracked EPlan License-Manager and cracked EiD-File for offline activation.
Then the activator will create a authorized license for EPlan.
its look like, that you have to write the files by yourself, there is no download option.
The more comfortable way will be to use the VM as License Server. (thnx)
pinkzwinkz
Post by pinkzwinkz »
Is it possible to add more modules to license file in the SERVER EPLAN VM license file? I need specific module. 2.9.4 cracking method was able to make license file based on TPL modules and I was able to add there.
twatson
Post by twatson »
It's September now, and we are waiting for the release of the eplan 2026 version (suc) (thnx)
