Тools, Elcad, Eplan, ...
Patrikrou
Post by Patrikrou »
wconan100 wrote: Sat Feb 15, 2025 3:17 pm hello...friend would it be possible for you to make this virtual machine available on another hosting...I can't download it because I'm not from your region (Country)
you can use baidudownloader.com to download (the link I attached in the message above).
P.S. With this crack you can open any version of eplan p8 at the same time.
aacoa666
Post by aacoa666 »
@Patrikrou
i downloaded the vm, but what I have to do next?
Could you please explain how to make it working?
would be greatful (oo)
wconan100
Post by wconan100 »
thank you for your feedback (suc)
For2024
Post by For2024 »
It would be great to have a download link that works outside of China. Alternatively, if someone has already downloaded it, they could share it via a file-sharing service like Filemail, Google Drive, or any other file-sharing platform. Let's help each other out! :wink:
Shein
Post by Shein »
aacoa666 wrote: Sat Feb 15, 2025 10:59 pm @Patrikrou
Hello Dear,
Can you help us to share?
Thank you very much... (oo) (oo) (oo)
aacoa666
Post by aacoa666 »
take a seat,
there is not that much time left before it will be delete.
(thnx)
https://drive.google.com/drive/folders/ ... drive_link
Patrikrou
Post by Patrikrou »
follow the installation instructions up to minute 12 of the video in the link below. (after the 12th minute I didn't really understand what he was doing)
https://www.bilibili.com/video/BV1rBCNY ... 303bcedd1f
you can directly use eplan 2025 (in Chinese) from the virtual machine, without following the instructions in the video.
1. If you will not use eplan 2025 from the virtual machine, you must install on windows any version of eplan p8 (2022, 2023, 2024, 2025) without crack.
2. follow the instructions in the video to access the license server.
3. open eplan (any version), the "license activation" window will appear, select "connect to license manager"
4. enter the ip address of the virtual machine, then connect to the server with the connection data set to "point 1".
I hope I can help you with this little tutorial (tyou)
aacoa666
Post by aacoa666 »
EPlan said, the License is not working for this device, by connection with the VM (no)
Any solutions?
Patrikrou
Post by Patrikrou »
check the installation instructions carefully.
after opening the virtual machine, check the machine settings, open "network adapter" and see if both are selected under "device status".
Shein
Post by Shein »
aacoa666 wrote: Sun Feb 16, 2025 1:39 pm take a seat,
(thnx)
Dear Bro,
Thanks you very mich... (oo) (oo) (oo)
For2024
Post by For2024 »
It doesent work for me . I get error MAX 15.21 127.0.0.1
aacoa666
Post by aacoa666 »
Make sure that you click „i moved it“, when u start the vm.
Then there should not be a error.
Patrikrou
Post by Patrikrou »
For2024 wrote: Sun Feb 16, 2025 5:05 pm you can directly use eplan 2025 (in Chinese) from the virtual machine, without following the instructions in the video.
if you followed all the steps correctly, try to restart windows. After that, start the virtual machine again, then try to open eplan.
127.0.0.1 is not the IP of the virtual machine?
you must connect with the current IP of the virtual machine.
also check if in the license folder you have a file that starts with SRV-
pinkzwinkz
Post by pinkzwinkz »
I just want to thanks for the VM via google drive. Really appreciate the help on this forum. It works on VM with "I moved it" , do not choose "I copied it"
For2024
Post by For2024 »
I would also like to sincerely thank everyone for their cooperation. Everything is working perfectly on my end as well!
The Google Drive sharing was a huge step forward, and after that, this forum practically became a hotline for support.
Many thanks to everyone! (pgood)
aacoa666
Post by aacoa666 »
(thnx) (tyou)
so have fun everyone and have a great time (welc) (thnx)
leonardo57
Post by leonardo57 »
alafandy wrote: Fri Jan 24, 2025 6:43 pm RIGHTNOW NO SOLUTION FOR EPLAN 2025
Connect to License Manager (MAX 13.39)
The License Client was not installed completely.
Please install the program again.
Check license (MAX 73.04)
An error occurred while reading the licenses.
Error 210092
The given license code is invalid. Hence, it could not be added to the
"no-net" license Server.
solid9009 wrote: Tue Dec 10, 2024 10:57 pm Hi, I'm trying to get the EPLAN Harness working, but I'm getting always a license error 210092 the given license code is invalide. Hence it could not be added to the "no-net" license server
I have generated the license with the keygen which was included. I have tried V23 and V24, but always same error.
What do I wrong?
Esmigol wrote: Thu Apr 18, 2024 12:08 am Hello, I get a problem when trying to activate Eplan 2024 with error 210092, does anyone know how I can solve it, I use Windows 11 Insider Pro
Did you find a solution for error 210092 ?? it happened to me and now i cant open any previous version of Eplan :( I have Windows 10 Pro 22h2
aacoa666
Post by aacoa666 »
run the vm, build a connection between vm and host.
follow the instructions of the chinese guy in the video.
this error should not matter if u can connect to the vm license server or not.
engpob
Post by engpob »
eddiedon wrote: Tue Feb 11, 2025 2:13 pm the man use a VMware to be a license server and push the license . then he can use eplan2025
https://www.bilibili.com/video/BV1rBCNY ... f1a4a98591
Friends, how did she make this virtual machine? Are there any instructions?
:D
zheng1205
Post by zheng1205 »
Steps for cracking network licenses
1. The Elm.exe ElmConfig. exe files in the C: \ Program Files \ EPLAN \ ELM directory need to be cracked. (The cracked file has been lost and needs someone to crack it again)
2. The first step in starting ElmConfig. exe is to activate the authorization manager using lservrc_88888888-88888-8888-8888-888888888-01;
3. After the authorization manager is successfully activated, the first step is to use lservrc_88888888888-88888-8888-8888-888888888-02 to activate network authorization and generate SN-N88888.EGF.
4. The generated SN-N88888.EGF is the same as the genuine . In this case, deleting the cracked Elm.exe ElmConfig. exe file and restoring the normal Elm.exe ElmConfig. exe file can enable normal authorization.
Two forged files of lservrc_88888888-88888-8888-8888-888888888 can be provided, Elm.exe ElmConfig. exe requires someone with OD capability to solve it
zheng1205
Post by zheng1205 »
If you have a genuine lending module, there is a way to extend unlimited lending times. This is only for internal use and there is a risk of leakage.
RadoTN
Post by RadoTN »
Could you please help me how to disable this option: "Skip identity check (ID=1450)" in Eplan License Manager ? Is there a solution to do this ?
screen
gino_007
Post by gino_007 »
Yes, it’s works but I can’t Chinees. Can I change te language to English or other.
For2024
Post by For2024 »
"First, enable internet access on the virtual machine, then go to the virtual machine settings and add the language you want. Restart the virtual environment, and the virtual machine will be available in the desired language. After that, change the virtual network adapter to 'Host-Only'."
gino_007
Post by gino_007 »
:D , Thx, Eplan 2025 on VM works, (pgood) .
BigPlans88
Post by BigPlans88 »
Hey,
How to change the language on Eplan from Chinese to English (or other language) ? I have managed to change the windows environment already.
/BigP
tektek
Post by tektek »
VM It doesn't work for me.
I use this version:
The errors I get in the virtual machine
For2024
Post by For2024 »
Go to the Programs installation menu on the virtual machine, find the EPLAN Electric 2025 program, then click Modify. In the dropdown installer menu, you can add or remove languages and set the default language for the interface. Click OK, install, and restart virtual machine. Done.
thanh3386
Post by thanh3386 »
(sos) Please reup link Eplan 2025. Thanks (tyou) (tyou) (tyou)
aacoa666
Post by aacoa666 »
Donau
Post by Donau »
Can someone re-record and upload the video in a higher quality.
It is sometimes hard to figure out what the person is doing.
https://www.bilibili.com/video/BV1rBCNY ... 1a4a98591
wconan100
Post by wconan100 »
thanh3386
Post by thanh3386 »
tektek
Post by tektek »
I downloaded it again and now it works for me. Thank you so much !!!
I have managed to change the language of Electric and Propanel, but can the language of the rest be changed? Could those applications (cable, fluid, ...) be reinstalled without losing the license?
aacoa666
Post by aacoa666 »
try it, u cant do something wrong (pgood)
But I think its much easier to use the vm as license server and work on your host pc :)
leonardo57
Patrikrou wrote: Sun Feb 16, 2025 1:46 pm follow the installation instructions up to minute 12 of the video in the link below. (after the 12th minute I didn't really understand what he was doing)
I think the third step is to run the virtual machine on another PC within the same local network, that way you don't have to have the virtual machine running on the same PC where you use Eplan
Also, the virtual machine only uses the ELM Configurator and EPLAN Smart Production, so it requires less resources.
Thanks for yor tutorial!
Donau
Post by Donau »
I keep getting the MAX19.42 error when connecting a native machine to the VM.
I have done all the steps in the video up to 14 minutes.
I'm sure my username and password are ok.
I can ping the VM, and the firewall is off.
Anyone able to help me out further?
Update: Got it running after reinstalling the client on the native machine.
h4rdw4re
Post by h4rdw4re »
For2024 wrote: Fri Feb 21, 2025 3:19 pm Go to the Programs installation menu on the virtual machine, find the EPLAN Electric 2025 program, then click Modify. In the dropdown installer menu, you can add or remove languages and set the default language for the interface. Click OK, install, and restart virtual machine. Done.
How did you manage that?
Setup ask for EPLAN Platform 2025.msi file which is not available as it is on shared drive (\\vmware-host\Shared Folders\EPLAN\EPLAN Setup\EPLAN_2025\Platform\).
Can anyone share Eplan 2025 setup, as all links are dead.
Or can someone share EPLAN Gui en-US 2024.exe from setup?
leonardo57
You need to download the program installers from this link.
https://drive.google.com/drive/folders/17vgR1EtBRfE30AwMWJVameDiW8GOhy8e
Then when it asks you for them during the installation, you select them from your shared folder with the VM or you can copy them directly into it.
Then to change the language inside the program I recommend you use Google Translator on your cell phone to understand the program menus.
h4rdw4re
Post by h4rdw4re »
I will download as soon as the quota allow it.
Right now to many parallel downloads.
Update:
Done. Thank you mate.
It works perfectly. All in English now and updated to latest version.
Best regards.
xiaxiang
Post by xiaxiang »
Can you post two lservrc files here? Just Baidu drive,many thanks.
dgumal_
Post by dgumal_ »
Hello everyone.
Who have EPLAN Smart Production Collection 2025, please share.
zens
Post by zens »
In the video clip from the web address https://www.bilibili.com/video/BV1rBCNY ... f1a4a98591, the final step shows permanent licensing without the need for a VM, by dragging the license from the VM to the computer. How was this done, does anyone know? In the License manager, 'liqb.us.kg' is entered, presumably the name of the server, and after that, a permanent license is obtained. How?"
gino_007
Post by gino_007 »
[b[/b]
Yes, it works, I entered the settings up to minute 12. (oo) (suc)
wconan100
Post by wconan100 »
Alex Pro
Post by Alex Pro »
НОВОЕ ЛЕКАРСТВО!! А точнее не лекарcтво, а полноценный сервер лицензий для eplan 2,0-2025 на Виртуальной машине VMWare на локализованной русской Винде.
NEW CURE!! Or rather, not a medicine, but a full-fledged license server for eplan 2.0-2025 on a VMWare Virtual Machine on localized Russian Windows.
https://rutracker.org/forum/viewtopic.php?t=6656751 (suc) (suc) (suc)
igbt
Post by igbt »
Alex Pro wrote: Wed Mar 05, 2025 1:08 pm ... сервер лицензий для eplan 2,9-2025 на Виртуальной машине VMWare...
Великолепно! Ждём окончания модерации раздачи. А можно ли сконвертировать образ в виндовый хайперВ?
Link
Eplan 2025 + keygen server
Post by Link »
(mirr) https://disk.yandex.ru/d/ruYZAnnzOggaOw
Eplan 2025 + keygen server from https://rutracker.org/forum/viewtopic.php?p=87493290#87493290
Russian
Сервер лицензий EPLAN 2,9-2025 (Виртуальная машина > VMWare 17,5)
Год/Дата Выпуска: 2025
Версия: 2025
Разработчик: ChinaHacker
Сайт разработчика: нет
Разрядность: 64bit
Язык интерфейса: Русский
Таблэтка: не требуется
Реклама: отсутствует
Системные требования:
Window 10 и выше.
Описание: Виртуальная машина - Сервер лицензий EPLAN 2,9-2025 на VMWare версии 17,5 или выше
Новое "лекарство", а точнее не лекарство, а реальный сервер лицензий на виртуальной машине для Eplan от v2.9 до 2025, без "бубна" и тормозов в работе.
Следуйте указаниям с скриншотах.
Нужно запустить VMware, открыть там ВМ.
ВМ сервера запускать только через "I MOVED", иначе сломаете машину!
Выяснить IP адрес виртуальной машины.
Определение IP-адреса виртуальной машины (сервера).
1 Откройте командную строку сервере. В Windows нажать Win + R, ввести "cmd" и нажать Enter.
2. В командной строке введите команду "ipconfig" и нажмите Enter.
3. Найдите строку "IPv4-адрес" или "IPv4 Address". Рядом с этой строкой будет указан IP-адрес ВМ. Например, "192.168.1.100", который нужно внести в адрес менеджера лицензий при первом запуске ePlan. и ВуАля...
Доп. информация: Windows key:eplan
User licence manager: xx\EPLAN
Pass: 5379
VMWare можно взять тут:https://rutracker.org/forum/viewtopic.php?t=6492639
Для запуска ВМ в фоновом режиме создать батик с текстом:
"C:\Program Files (x86)\VMware\VMware Workstation\vmrun.exe" start "C:\VMware Workstation\SERVER\EPLAN 2025.vmx" nogui
путь в ВМ прописать свой и закинуть в startup.
Никакие настройки менять не рекомендуется, рискуете "сломать" сервер лицензий eplan!
English
EPLAN License Server 2.9-2025 (Virtual Machine > VMWare 17.5)
Year/Release Date: 2025
Version: 2025
Developer: ChinaHacker
Developer's website: no
Bit depth: 64bit
Interface language: Russian
Tablet: not required
Advertising: none
System requirements:
Window 10 and above.
Description: Virtual Machine - EPLAN License Server 2.9-2025 on VMWare version 17.5 or above
A new "cure", or rather not a cure, but a real license server on a virtual machine for Eplan from v2.9 to 2025, without "tambourine" and brakes in operation.
Follow the instructions in the screenshots.
You need to run VMware, open the VM there.
Run the server VM only via "I MOVED", otherwise you will break the machine!
Find out the IP address of the virtual machine.
Determining the IP address of the virtual machine (server).
1 Open the command line on the server. In Windows, press Win + R, enter "cmd" and press Enter.
2. In the command line, enter the command "ipconfig" and press Enter.
3. Find the line "IPv4 address" or "IPv4 Address". The IP address of the VM will be indicated next to this line. For example, "192.168.1.100", which must be entered in the license manager address when you first start ePlan. and Voila...
Additional. information: Windows key:eplan
Pass: 5379
VMWare can be taken here: https://rutracker.org/forum/viewtopic.php?t=6492639
To start VM in the background, create a batik with the text:
write your own path to VM and throw it into startup.
It is not recommended to change any settings, you risk "breaking" the eplan license server!
h4rdw4re
Post by h4rdw4re »
According to the disk size and language visible on photos (Chinese), could it be possible that this one is only stripped version, i.e. removed ePlan and all components except license of complete ePlan2025 already posted on forum?
Someone already posted that previous disk can be used as license server also.
ragundo
Re: Eplan 2025 + keygen server
Post by ragundo »
What's the password for login in the VM?
img https://u.pcloud.link/publink/show?code ... BLB5WRmmD7
I can't continue the process because I can't login!!!
EDIT: I found the solution. For non russian people, change the language input method to english.
The password is eplan
Greetings
