[?+]: Weintek XOB file unpassword
necrohamcer
Re: Weintek HMI .xob file password
Post by necrohamcer »
dilanawan wrote: Wed Jan 26, 2022 2:28 pm Dear vlad2006gr,
could you please help me to decompile this XOB file? I dont know what should i do
please, Your help will be appreciated.
https://drive.google.com/file/d/1P4rjre ... sp=sharing
Check your PM
necrohamcer
hsbscool wrote: Sat Jan 15, 2022 11:12 am Sir can you decompile my file xob (eb8000 weintek series).
https://www.mediafire.com/file/dyolc9s5 ... I.xob/file
Check your PM
necrohamcer
vivend wrote: Mon Jan 03, 2022 5:13 am Dears,
Please decompile this XOB file for me.
Thank you in advance,
Vivend
https://1drv.ms/u/s!Ah7H2Zs3oO6igYpYYQ4 ... g?e=2y7rZp
Check your PM
necrohamcer
rkhamdamov wrote: Sat Dec 04, 2021 6:01 am Hi all!
I have exob file from weintex mt8071ie locked, can you help me to ulock?
Exob file: https://drive.google.com/file/d/1ywLmpO ... sp=sharing
Thanks in advance.
Rustam
Check your PM
mrdona2098
Post by mrdona2098 »
can you decompile my XOB file???
Thanks,
https://www.mediafire.com/file/q8h6w1se ... i.xob/file
necrohamcer
mrdona2098 wrote: Thu Apr 14, 2022 5:28 pm Hello,
Thanks,
Check your PM
legzylart
Post by legzylart »
Please help me to decompile this file
https://drive.google.com/file/d/18L1Faf ... sp=sharing
necrohamcer
legzylart wrote: Tue Apr 19, 2022 6:47 pm Hello,
I assume your HMI is MT8071IE and you took a project copy using a usb flash drive, right? There's something strange about this series. Could you take another copy of your HMI on the flash drive and send me all those contents (not just the exob)? It's still going to take a while to figure it out but the more information I have, the better.
yacinio87
Post by yacinio87 »
HI i have weintek kt6070 i want unlock xob file if you helpe me my mail yacinio87@gmail.com this is the link of the file https://files.fm/u/fr28jcrh3
legzylart
Post by legzylart »
necrohamcer wrote: Wed Apr 20, 2022 6:57 am
Thanks for the feedback, Yes the device is MT8071IE and the project was download using Ethernet with Easybuilder.
Please find the new files here:
necrohamcer
yacinio87 wrote: Wed Apr 20, 2022 11:07 am HI i have weintek kt6070 i want unlock xob file if you helpe me my mail yacinio87@gmail.com this is the link of the file https://files.fm/u/fr28jcrh3
Check your PM
milly
Post by milly »
Can someone please help me to decompile this file:
https://drive.google.com/file/d/1O0Txfv ... sp=sharing
Thanks!
gycu
Post by gycu »
Hi guys,
Can you help me decompile this?
https://drive.google.com/file/d/1hoGx-- ... 5LFFcK2xa0
Thanks a bunch!
Cheers!
milly
Post by milly »
After the password was reset, when I try to load file (with no other modification) on the HMI, I get the error that the incompatible project settings. Any ideas? I am using Easybuilder8000. My screen is TK6070IP, but I only see MT6070IP in the System Parameters menu option.
necrohamcer
milly wrote: Thu May 12, 2022 8:55 pm Hello,
Thanks!
Check your PM.
EB screen
necrohamcer
gycu wrote: Sat May 14, 2022 9:44 am Hi guys,
Thanks a bunch!
Cheers!
Check your PM
EB screen
necrohamcer
milly wrote: Mon May 16, 2022 2:53 pm After the password was reset, when I try to load file (with no other modification) on the HMI, I get the error that the incompatible project settings. Any ideas? I am using Easybuilder8000. My screen is TK6070IP, but I only see MT6070IP in the System Parameters menu option.
TK6070iP is the chinese series of the HMI. You need to install EB8000 in chinese language and set your computer system locale to chinese also.
You can do that by opening Control Panel>Clock & Region>Change date, time, or number formats>Administrative>Change system locale. Select Chinese Simplified, hit OK and reboot your computer.
After that open EB8000 and the TK series will appear in the list.
ideed354
Post by ideed354 »
Please help me to open lock... many thanks before
link file : https://drive.google.com/drive/folders/ ... sp=sharing
bakiro2005
Post by bakiro2005 »
PLEASE WOULD YOU HELP ME TO CONVERT THE WEINVIEW TH6070IP HMI XOB TO MTP OR UNLOCK THE XOB FILE THAT WOULD BE SO HELPFULL
THANK YOU IN ADVANCE FILE BELLOW LINK
https://www.4shared.com/file/euXZ595Iea ... 070IP.html?
:D (pgood) (pgood)
necrohamcer
ideed354 wrote: Sat Jun 11, 2022 4:59 am Please help me to open lock... many thanks before
Check your PM
necrohamcer
bakiro2005 wrote: Mon Jun 20, 2022 5:56 pm PLEASE WOULD YOU HELP ME TO CONVERT THE WEINVIEW TH6070IP HMI XOB TO MTP OR UNLOCK THE XOB FILE THAT WOULD BE SO HELPFULL
:D (pgood) (pgood)
Check your PM
bakiro2005
:D :D :D :) :) :) :) (pgood) (pgood) (pgood) (pgood) YOU ARE VERY HELPFULL THANK YOU VERY MUCH
thedanh7218u
Re: XOB file password
Post by thedanh7218u »
vlad2006gr wrote: Thu May 08, 2014 6:44 am Send me a project *. Xob format, I decompiled the project and send you.
i have HMI weintek Mt6071ip.
i uploaded xob file
i can't decomplie because i don't have password..
Can you help me...please...
thankyou very much
https://drive.google.com/file/d/1FLwFuf ... sp=sharing
necrohamcer
I've sent the password in your PM.
Olson
Post by Olson »
Hello, sir.
Need your help, please.
Can you help me to decompile ? Link below.
https://we.tl/t-wuqcOVucN1
HMI Model : MT6071iP
Thank you in advance.
Olson.
necrohamcer
Olson wrote: Fri Jun 24, 2022 9:36 am Hello, sir.
Olson.
Check your PM
Olson
Post by Olson »
necrohamcer wrote: Fri Jun 24, 2022 4:28 pm
Olson.
Check your PM
You did GREAT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It's working fine !!!
Thank you very much, sir !!
Power to YOU !
Kevin83
Post by Kevin83 »
Could anyone help me please.
I need to decompile my XOB file to change the HMI program.
Pls find the file in the link below:
https://drive.google.com/file/d/1_nQPXR ... sp=sharing
Really appreciate your kind support. (tyou)
acdwkr
Post by acdwkr »
I need to change the HMI type for this project, could you please help me and unlock this file.
Thanks you in advance
https://drive.google.com/file/d/1dztMr4 ... sp=sharing
mukovic
Post by mukovic »
The program was made a long time ago, but the password was forgotten. Can you help me to edit it please.
https://drive.google.com/file/d/1KCH2Jz ... sp=sharing
necrohamcer
Kevin83 wrote: Fri Jul 01, 2022 9:23 am Could anyone help me please.
You haven't shared the file with everyone, I can't download it.
necrohamcer
acdwkr wrote: Sat Jul 02, 2022 9:32 am Hello,
necrohamcer
mukovic wrote: Wed Jul 06, 2022 3:18 pm Hi
I answered your other post in the russian thead, the password is in your PM.
ghulamshoaib
Post by ghulamshoaib »
Hello Everyone
I have exob file abd I want to decompile it
It showing message that file is protected and cannot be decompile
Any solution
Waiting
j_hooper
Post by j_hooper »
Hello, found this thread looking for a way to decompile an old program. Password is long forgotten. Help please:
https://drive.google.com/file/d/1KgBoyr ... sp=sharing
Jeff
necrohamcer
ghulamshoaib wrote: Tue Jul 19, 2022 8:04 am Hello Everyone
Any solution
Waiting
You could upload the exob here, just saying.
fairooz313
Post by fairooz313 »
dear vlad
can you decompile it
https://we.tl/t-9wnwyZdXsv
muhammadali7712
Need to decompile the attached Weintek HMI .xob file
Post by muhammadali7712 »
Hello dear I have a xob file of weintek hmi when I am trying to decompile the xob file then got the message is the XOB must be newer tool.
Hmi model is MT 6071ie
Using software is easy builder pro v 6.07.02.
File link is
https://www.mediafire.com/file/hv1dyvfl ... .exob/file
Can you decompile the file in edit able file I am thankful to you.
corndog
Post by corndog »
hello, i need help to decompile a file for the mt8071ip please help
https://www.mediafire.com/file/98wu8m9e ... .exob/file
andreyit
Post by andreyit »
corndog wrote: Tue Aug 02, 2022 10:01 am hello, i need help to decompile a file for the mt8071ip please help
Just decompile this file in ebpro 6.06.02 with password 111111.
necrohamcer
fairooz313 wrote: Sun Jul 24, 2022 1:54 am dear vlad
Your file expired, can you send it again?
necrohamcer
Re: Need to decompile the attached Weintek HMI .xob file
muhammadali7712 wrote: Tue Jul 26, 2022 5:47 am Hello dear I have a xob file of weintek hmi when I am trying to decompile the xob file then got the message is the XOB must be newer tool.
File link is
Can you take a another backup of the project from the HMI using a usb flash drive? Send me the contents of the drive after that.
KreatorBuki
Post by KreatorBuki »
Can you help me to unlock pasword for this project :
https://drive.google.com/file/d/1ncyxpM ... sp=sharing
It is Weintek MT6070iH 2WK
necrohamcer
KreatorBuki wrote: Thu Aug 25, 2022 12:34 pm Can you help me to unlock pasword for this project :
Check your PM.
farhhan
Post by farhhan »
dear sir,
please unlock xob
https://www.mediafire.com/file/fw75owq2 ... w.xob/file
thanks and regard
yeronix
Post by yeronix »
I need to decompile this file:
https://drive.google.com/file/d/1-f8Ekd ... sp=sharing
i hope you can,
necrohamcer
farhhan wrote: Mon Aug 29, 2022 12:10 pm dear sir,
please unlock xob
thanks and regard
Check your PM.
necrohamcer
yeronix wrote: Wed Aug 31, 2022 1:40 pm Hello,
i hope you can,
Check your PM.
Hozefa
Post by Hozefa »
tg_elec
Post by tg_elec »
hello dear vlad
i have weintek MT8090XE panel with password protected EXOB file.please help me to decompile it.
thanks in advanced
