Fatek Protected File
другие контроллеры
Mory613
Re: Fatek Protected File
Post by Mory613 »
Mory613 wrote: Wed Oct 13, 2021 3:24 am Hi,
Could you please help me to know password this program?? (oo) (oo)
Thank you so much! (tyou)
https://drive.google.com/file/d/17Rg_tl ... sp=sharing
please help, I really need to find that password (oo) (oo)
MarCus0
Post by MarCus0 »
Hi All
Can You help to know PLC password, please?
https://www.mediafire.com/file/q7m0b84e ... C.pdw/file
Regards
Marek
berrter
Post by berrter »
MarCus0 wrote: Thu Oct 28, 2021 11:00 am Hi All
Regards
Marek
MAR103 enjoy :D
fatekber2020
Post by fatekber2020 »
Hi All
Can You help to know PLC password, please? (oo) (oo) (oo) (oo) (oo)
https://www.mediafire.com/file/faju6tpr ... t.pdw/file
berrter
Post by berrter »
fatekber2020 wrote: Tue Nov 02, 2021 12:47 pm Hi All
CKY9998
fatekber2020
berrter wrote: Tue Nov 02, 2021 2:18 pm
CKY9998
Thank you so much (pgood) (pgood) (pgood) (pgood) (pgood)
how will they contact you? , they helped me a lot
Mory613
Post by Mory613 »
Mory613 wrote: Mon Oct 25, 2021 3:42 am
please hlep (h)
berrter
Post by berrter »
Mory613 wrote: Wed Nov 03, 2021 5:34 am
please hlep (h)
190130
berrter
Post by berrter »
berrter wrote: Wed Nov 03, 2021 9:56 am
please hlep (h)
190130
You Project mast be opened cracked Winproloader, no need password , you no need password :) cracked Winproloader find on web
berrter
Post by berrter »
and yet, many passwords are in this thread, the manufacturer from SRPACK or INOVA . may bee others in different countries, he password is the same :)
gssantos
Post by gssantos »
dj1178
Post by dj1178 »
gssantos wrote: Wed Nov 10, 2021 1:53 pm Hi!
Could u send the password:
https://drive.google.com/file/d/1HxpuA7 ... sp=sharing
(h) (h) (h)
please use other web upload it again
HelpYou
Post by HelpYou »
dj1178 wrote: Tue Dec 14, 2021 7:32 am
(h) (h) (h)
Drop the file again! (boom)
HelpYou
Post by HelpYou »
(h) (h) (h)
dj1178
Post by dj1178 »
HelpYou wrote: Mon Dec 20, 2021 12:12 pm
(h) (h) (h)
I cannot download the file from Google
dynak
Post by dynak »
Hi all. Who knows how to open the program data protection?
Thanks in advance.
dipesh1410
Post by dipesh1410 »
Hi..
Share your File..
dj1178
Post by dj1178 »
dynak wrote: Fri Dec 24, 2021 6:11 pm Hi all. Who knows how to open the program data protection?
Thanks in advance.
I can
Ottoman
Post by Ottoman »
nabat wrote: Fri Oct 22, 2021 10:25 am
Ottoman wrote: Tue Oct 05, 2021 7:03 am
Ottoman wrote: Thu Sep 30, 2021 6:06 am Hi, good day to all,,,,
Please help with password for Sub-programs for following fatek program:
https://www.mediafire.com/file/l7wojszr ... 1.pdw/file
Please HELP!! (h)
19911112 best regards
Thank you that was helpfull, (thnx) (thnx) (thnx) (thnx) (thnx) (thnx) (thnx) (thnx) (thnx) (thnx)
metwally
Post by metwally »
please i need this program password
https://drive.google.com/file/d/17rbBFW ... sp=sharing
dipesh1410
metwally wrote: Sun Jan 02, 2022 7:45 am please i need this program password
Access Denied..
Kindly share your file with other host or without restriction..
Thanks..
SHAHZAD AZIZ
Post by SHAHZAD AZIZ »
All plc & Hmi password crack. Contact number.+923464162377. Gmail. shahzadaziz292@gmail.com
matabig1995
Post by matabig1995 »
hello
can you find the password for this file
https://send.cm/d/7FEv
metwally
Post by metwally »
dipesh1410 wrote: Sun Jan 02, 2022 3:39 pm
Access Denied..
Thanks..
please help to crack this program
https://www.mediafire.com/file/tk35bcsi ... 1.pdw/file
dipesh1410
metwally wrote: Mon Jan 03, 2022 7:43 am
Access Denied..
Thanks..
Password Main : KAYASARA
Thanks...
dj1178
Post by dj1178 »
matabig1995 wrote: Mon Jan 03, 2022 12:49 am hello
so easy
it's a Chinese name
metwally
Post by metwally »
dipesh1410 wrote: Mon Jan 03, 2022 1:58 pm
Access Denied..
Thanks..
Thanks...
thank you so much
matabig1995
dj1178 wrote: Tue Jan 04, 2022 1:28 am
so easy
it's a Chinese name
What is is!!?
matabig1995
Access Denied..
Thanks..
Thanks...
fatekber2020
Fatek ID file (fatek (a) .cif)
Who can tell, the Fatek FBs controller, when trying to connect or look at its status, disconnects the connection with an error - Can not open the customer ID file (fatek (a) .cif).you need to extract the project file, or run after stopping. unable to run because there is protection. who solved this problem?
or switch from Stop to run state, it has to be done through the programmer FP-07C (sos) (sos) (sos)
День добрый!
Кто может подсказать, контроллер Fatek FBs, при попытке соединиться или посмотреть его состояние отключает соединение с ошибкой - Can't open the customer ID file ( fatek(a).cif).нужно извлечь файл проекта или запустить после остановки. запустить не удается потому что есть защита. кто как решал данную проблему?
или переключиться из состояния Stop в состояние run , это необходимо сделать через программатор FP-07C где искать кто знает ? (sos) (sos) (sos)
dipesh1410
matabig1995 wrote: Tue Jan 04, 2022 5:13 pm
Access Denied..
Thanks..
Thanks...
Main: 81492213
Thanks...
matabig1995
dipesh1410 wrote: Wed Jan 05, 2022 2:00 pm
Access Denied..
Thanks..
Thanks...
Main: 81492213
Thanks...
Many thanks
you are a saviour!!
andreyit
Re: Fatek ID file (fatek (a) .cif)
Post by andreyit »
fatekber2020 wrote: Wed Jan 05, 2022 1:29 pm Who can tell, the Fatek FBs controller, when trying to connect or look at its status, disconnects the connection with an error - Can not open the customer ID file (fatek (a) .cif).you need to extract the project file, or run after stopping. unable to run because there is protection. who solved this problem?
День добрый!
Про fatek(a).cif и customer ID file писали еще на первый страницах темы, что с этим вы ничего сделать не сможете не получив от изготовителя оборудования этот файл.
С переводом в RUN может быть такая же штука, что в программе плк это заложено (как в мицубишевскийх плк это есть через спец маркера), и ничего не сделаете. Возможно это защита от неоплаты или принудительного техобслуживания через изготовителей оборудования.
fatekber2020
Всем привет , Удалось запустить run на Fatek? осталась проблема как сменить скорость ком порта , он стал по дефолту 9600 , а нужно 38400 ???? или есть метод как сохранить проект ? за любой комент большое спасибо
andreyit
Post by andreyit »
fatekber2020 wrote: Mon Jan 10, 2022 3:32 pm Всем привет , Удалось запустить run на Fatek? осталась проблема как сменить скорость ком порта , он стал по дефолту 9600 , а нужно 38400 ???? или есть метод как сохранить проект ? за любой комент большое спасибо
Если в PLC>Setting>Protocol можно что-то менять, то замените первый или второй порт на modbus (нулевой порт не поддерживает). И теперь можете попытаться в регистр R4146 (порт 1) или R4158 (порт 2), записать данные. Сейчас там 5621 в шестрадцетеричке, что значит 9600 bps 7-bit Data, Even、1-bit Stop, вам надо 5663, что 38400 bps 8-bit Data, Even.
Инфо о коммуникации. Инфо о том как высчитать адрес для modbus посылки.
Если нельзя менять, или не сохраняется, то ничего не сделать... Хотя можно еще любой скадой подключится т.к. там используется протокол фатековский которому не надо настройку делать, если через порт 0, и уже через скаду изменить число.
fatekber2020
andreyit wrote: Mon Jan 10, 2022 4:38 pm
(welc) (welc) (welc)
Большое спасибо за ответ очень благодарен . У меня нет возможности что-то изменить через Winprolader потому что заблокирован (ev) контролер под файл CIF на которий я не нашел информации , с контролерем чтото случилось что он из RUN вошел в режим STOP режим я включил он запустился , но настройки порта теперь по дефолту 9600 програма не соединяется , можно поподробей о скада , возможно ли изменить настройки на самом контролере кроме winprolader . Большое спасибо что отписал (oo) (oo) (oo) , долго уже вожусь с етим контролером но результата нет , слил би прошивку но как ? (h) (h) (h)
andreyit
Post by andreyit »
fatekber2020 wrote: Tue Jan 11, 2022 10:13 am
Как уже писалось - слить прошивку невозможно, если у вас нет cif файла от производителя оборудования. Обойти невозможно.
А со скадой... Берете тип master scada, создаете подключение, экран, цифровое окно с разрешением менять, подключаетесь и надейтесь. Можно еще подключить панельку тип waintek и через неё попытаться изменить, тоже создав экраны и читать регистр нужный (нужен регистр, типа порта - modbus rtu или ascii, или fatek протокол, и скорость с параметрами).
Ставлю не очень большие шансы на это + может плк забыть эти изменения.
fatekber2020
Всем привет настройку порта я сменил , за ето большое спасибо !!!! от батарейки мог ли повредится проект на контролере ? как убедиться что програма на нем есть , может вичитать регистр ? как убедится что проект там еше есть ?
andreyit
Post by andreyit »
Если батарейка села, то вся программа пропала. Там стоит литиевая перезаряжаемая которой хватает на 6 месяцев, чтобы перезарядится хватает 12 часов
Ну, у вас требует cif, если бы программы не было, то и этого требования не было.
Krisger
Post by Krisger »
Hello guys,
Newbie here, please help me unlock subprogram menu.
https://rapidshare.io/1UZz/1_-1__Belt.pdw
dipesh1410
Password: FM06RU4A
Thanks..
Krisger
Post by Krisger »
Thank you very much! :)
Chuzz
Post by Chuzz »
Hello, could you help me. how can i download the program in plc fatek to upload the file? next i upload it t :shock: o know the password
xavi_zu
Post by xavi_zu »
Hi, i require to connect with fatek FBs-40MCt2-AC.. i tried to cracked with plc key 2.21 but it was impossible cause my PLC's Version is upper 4.52... some one who help for connecting and upload its programm into my pc...
seb_dev
Post by seb_dev »
please can you help me to get password for this file:
https://www.mediafire.com/file/x61togjd ... C.pdw/file
Thanx, Seba
mahmoud31
Post by mahmoud31 »
Please can you sent crack
mahmoudlook1@gmail.com (sos)
mjd-ee
Re: Fatek PLC Password
Post by mjd-ee »
hi all.
i have problem with FBs-20MC..
when i attempt to get online the winproladder gives a message, enter password or ID...
I want to modify the existing code but i don't know the passward...please help me..
thanks advance..
adamalvaro
Post by adamalvaro »
adamalvaro
Please download this file to crack...
https://www.mediafire.com/file/esuukryr ... d.rar/file
berrter
Post by berrter »
5433
