[Fishing ?]: RSLogix 5000 - Removing source protection
cuongvcs
Re: [Fishing ?]: RSLogix 5000 - Removing source protection
Post by cuongvcs »
skdatmonster3 wrote:What is the software version of RSLogix 5000 you are using, and what is the browser? Can you give a sample file that does not decrypt?
Dear skdatmonster3.
can you please fix this issue "Source key recovery is not supported for EncryptionConfig="8"
many thanks.
del24
Post by del24 »
(read) I have done.
I need help, how can i get de sk.file from this share about .ACD file.
I couldnt unprotect my file.
Please, help me.
del24
Post by del24 »
:anon:
I done by myself
Im need help to unproctet this file .ACD on share.
XXXXXXXXXXXXXXXXXXXXXXXXXX
Can I help me, how can get de sk.dat file this project?
engr27
Post by engr27 »
skdatmonster3 wrote: Mon Dec 01, 2014 3:54 am I have put up a new version of the tool again. It is at the same urls, see https://www.github.com/skdatmonster/Dec ... /README.md and http://skdatmonster.github.io/DecryptSo ... index.html
This version can now also handle EncryptionConfig="6" which is for newer versions of RSLogix 5000. However, in the new version, they have changed how source keys are stored, so it can't recover source keys when EncryptionConfig="6". I haven't finished looking at that, maybe I can fix it, maybe it would need rainbow tables. Even though, if a file is EncryptionConfig="6", you can still copy the decrypted XML out of the right box, save that in a new .L5X file, and import that into a project to get your logic back.
For those having trouble with XPath in browsers, you need to try with a different browser. I have tested the program in Firefox and Chrome and it is working. If your browser doesn't have XPath or XPathResult, then it won't work and you have to try with a different browser. If you cannot install another browser, maybe copy the file to a different computer and install it there?
Hi, how to handle found source key but shows UNPACKED ENCODED DATA
Unpacked encoded data
Found source key: "ŸãÛyԗ.+›‰¦ZLNí]r½-o¹Â‡tæ‚"
jetstream
Post by jetstream »
Curious if support for EncryptionConfig="8" or EncryptionConfig="9" will be updated.
Cheers!
