[?]: Load changed hardware in profibus
Josemi
Post by Josemi »
two questions:
when you change a profibus device (that have parameters) for example a encoder, is it necessary load the hardware configuration from step 7 or only make a reset to PLC.
Arethis parameters stored in the electronic of the device or no? (for example a encoder, a scanner or any profibus device )
Post by CoMod »
if you replace equal encoder - no need reupload HWConfig.
If you change encoder white difference quality (2048 step/rev to 8192 step/rev) required to reupload HWConfig.
Absolute Encoder have EEPROM (~1 000 000 cycle of rewrite) for setting logical "0" position and also for scale parametr.
Josemi
absolute Encoder
Post by Josemi »
The encoder is the same but it haves parameters (preset, resolution, CW or CCW... Is it nedessary reupload the hardware for this absolute encoder if I won't change any parameters (althought this parameters are diferent of default factory parameter
