[INFO] plcforum temp adress
O форуме и файлообменниках.
Правила (или почему могут забанить)
Post by CoMod »
"Ваш домен plcforum.uz.ua не продлен
Доменное имя plcforum.uz.ua требует продления."
Зеркало адреса https://plcforum.uz.ua
new adress https://plcforum.uz.ua
xflash
Re: [INFO] http://plcforum.ml temp adress
Post by xflash »
it also could be :
put this line in C:\Windows\System32\drivers\etc\hosts
5.29.158.219 plcforum.uz.ua
and run ipconfig /flushdns in cmd
wishes everybody come back soon.
Schtiel
Post by Schtiel »
plcforum.uz.ua is active again
Post by sania »
please use plcforum.uz.ua
save the link https://plcforumuzua.blogspot.com/ for check status with forum access problem
[INFO] http://plcforum.work.gd temp adress
Post by CoMod »
регистрацию plcforum.uz,ua каждые 2 года надо продлевать...
но в этом году пока не получилось...
запустили https://plcforum.uz.ua/
имена фамилии явки прежние
(mirr)
plcforum.uz.ua registration needs to be renewed every 2 years...
but this year it didn't work...
launched https://plcforum.uz.ua/
all logins work
gabcor
Re: [INFO] plcforum temp adress
Post by gabcor »
A little bit precisation:
from IT the domain as above is unavaiable but with the direct ip address 77.138.222.180 is showing the home page, but after a login (the logins data are saved!!) the browser point again to resolved address, with the above errors, but if sobstituting the resolved address with the above ip address the forum (with login credentials) is showing ...
Is the DNS problem solvable?
gabcor
Post by gabcor »
A bit more checks:
plcforum.uz.ua resolve correct to 77.138.222.180
but
https://plcforum.uz.ua cannot resolve
is possible to add a line to this DNS record for resolving also http:// ?
Regards
ahmed2a1a
I tried to mak lik this but it's not working please support
Post by ahmed2a1a »
Please support i can't open the forum all tried
Post by sania »
"http://" it isn't part of DNS record, but point to protocol & port used only
for check availability please follow to this tools
https://www.uptrends.com/tools/uptime
https://www.uptrends.com/tools/dns
for example traceroute from Milano to https://plcforum.uz.ua come within 85ms to right IP (77.138.222.180)
gabcor
Post by gabcor »
Hello Sania,
both PING and TRACERT works flawless, givimg me back the right IP resolved 77.138.222.180 (I think at this point that is the only website on this webserver)
I've found the point: my antivirus tell me that this domain is infected by BotNet ...
this is a scan by another authority
https://www.urlvoid.com/scan/plcforum.uz.ua/
clean ...
sorry for the trouble
Post by sania »
it`s because new domain & have no reputation.
our old domain was worked from around 2015.
but for sure, it`s the old forum, old physically server, old DBs, nothing not changed except domain name.
P.S. add our discussion to https://plcforumuzua.blogspot.com/
Post by sania »
Effective from 26.05 we will back to our old https://plcforum.uz.ua.
https://plcforum.uz.ua still for BACKUP only
Registration end.... Again...
Post by sania »
(mirr)
all logins work
xflash
Post by xflash »
It has been many days reconverting,
please consider put backup domain and blog in ekb release.
I guess many friends will check rutracker for forum status.
Good luck to all!
Post by sania »
Effective from 03.06.24 we will back to our old https://plcforum.uz.ua.
http://plcforum.work.gd still for BACKUP only
