e3.series.2009.v800-patch.exe:
http://www.eplan-eb2.ys168.com/
http://plcforum.uz.ua//e ... -patch.exe
or
http://narod.ru/disk/5219149000/e3.seri ... h.zip.html
[LINK]: patch and LIC for E3.Series.2009.v800
Re: [LINK]: patch for E3.Series.2009.v800
Copy the following into a text file and then renamed the copy license.dat to:
D: \ Program Files \ Cim-Team \ E3.series_2009
Or:
D: \ Program Files \ Cim-Team \ E3.series_2008
The contents of the authorization in 2008 and 2009 can be used in two versions, no longer need to crack the file, as long as the authority on it. Ha ha, I English is not good, who would this be translated into English now, huh, huh.
--------------------- text of LICENSE.DAT ------------------------如下:
Or:
把如下内容复制到一个文本文件里改名为license.dat后再复制到:
D:\Program Files\Cim-Team\E3.series_2009
或者是:
D:\Program Files\Cim-Team\E3.series_2008
该授权内容可以用于2008和2009两个版本,不再需要破解文件,只要这个授权文件就可以了。呵呵,我英文不好,谁会把这个翻译为英文吧,呵呵。
SERVER this_host ANY
VENDOR ECADLM
FEATURE Board ECADLM 8.000 permanent uncounted 897C6CE80FE6 \
VENDOR_STRING=PENGRUBIN HOSTID=ANY TS_OK
FEATURE E3MultiUser ECADLM 8.000 permanent uncounted C378B996204E \
FEATURE E3board ECADLM 8.000 permanent uncounted 247569F20D46 \
FEATURE E3cable_sb_to_prof ECADLM 8.000 permanent uncounted \
5F0EA9483117 VENDOR_STRING=PENGRUBIN HOSTID=ANY TS_OK
FEATURE E3cable_sb ECADLM 8.000 permanent uncounted D77056657F19 \
FEATURE E3cable ECADLM 8.000 permanent uncounted 175A686398D6 \
FEATURE E3caddyBasic ECADLM 8.000 permanent uncounted 067BBF3DDA43 \
FEATURE E3caddyEconomy ECADLM 8.000 permanent uncounted 96D09B6007D7 \
FEATURE E3caddyProfessional ECADLM 8.000 permanent uncounted \
052D3EA38207 VENDOR_STRING=PENGRUBIN HOSTID=ANY TS_OK
FEATURE E3exportEXF ECADLM 8.000 permanent uncounted 531C66081044 \
FEATURE E3logic ECADLM 8.000 permanent uncounted 11552265CCD3 \
FEATURE E3panel ECADLM 8.000 permanent uncounted 1DF8AB748468 \
FEATURE E3pdf ECADLM 8.000 permanent uncounted 86047D974C1C \
FEATURE E3redliner ECADLM 8.000 permanent uncounted A1898F954C97 \
FEATURE E3schema_sb_to_prof ECADLM 8.000 permanent uncounted \
5A34809A58CE VENDOR_STRING=PENGRUBIN HOSTID=ANY TS_OK
FEATURE E3schema_sb ECADLM 8.000 permanent uncounted 38992A4CCED8 \
FEATURE E3schema ECADLM 8.000 permanent uncounted D379789C02A0 \
FEATURE E3schema_to_cable ECADLM 8.000 permanent uncounted \
D551245B88D6 VENDOR_STRING=PENGRUBIN HOSTID=ANY TS_OK
FEATURE E3student ECADLM 8.000 permanent uncounted 9F9F5BF5026D \
FEATURE E3view ECADLM 8.000 permanent uncounted BACC1E6C5754 \
FEATURE E3viewPlus ECADLM 8.000 permanent uncounted 816CDF4597C3 \
FEATURE E3wire ECADLM 8.000 permanent uncounted E3503ED476EB \
FEATURE Plus ECADLM 8.000 permanent uncounted 1DFE09869D56 \
FEATURE dfb ECADLM 8.000 permanent uncounted 3A4E250E8972 \
FEATURE eco ECADLM 8.000 permanent uncounted 5480782C41D6 \
FEATURE frs ECADLM 8.000 permanent uncounted 589B7BD82A5D \
FEATURE multiuser ECADLM 8.000 permanent uncounted 5B2FAF13F309 \
FEATURE wireLINK ECADLM 8.000 permanent uncounted 7256E8D148E1 \
FEATURE E3sap-bom ECADLM 8.000 permanent uncounted 6987CF4A4EDA \
FEATURE E3sap-mat ECADLM 8.000 permanent uncounted FE079B955B2F \
FEATURE E3sap-dms ECADLM 8.000 permanent uncounted 34B6032ACC7E \
FEATURE E3_SolidEdge ECADLM 8.000 permanent uncounted 3C3B2187DE47 \
FEATURE E3_CATIA_V5 ECADLM 8.000 permanent uncounted 0460855C8933 \
FEATURE E3_ProE ECADLM 8.000 permanent uncounted 923E321272EB \
FEATURE E3formboard ECADLM 8.000 permanent uncounted 905D9ED05B05 \
FEATURE E3avionics ECADLM 8.000 permanent uncounted 029DF939A444 \
FEATURE E3cgm ECADLM 8.000 permanent uncounted 4CFE2502E068 \
FEATURE E3_MIL_Standard ECADLM 8.000 permanent uncounted 9287A7E39735 \
FEATURE E3_STEP_AP212_ELOG ECADLM 8.000 permanent uncounted \
7F90851F3B13 VENDOR_STRING=PENGRUBIN HOSTID=ANY TS_OK
FEATURE E3_STEP_AP212_KBL ECADLM 8.000 permanent uncounted \
7A5015FAA06B VENDOR_STRING=PENGRUBIN HOSTID=ANY TS_OK
FEATURE Board ECADLM 7.000 permanent uncounted D9E0BC50FA0A \
FEATURE E3MultiUser ECADLM 7.000 permanent uncounted 6102AB973BA1 \
FEATURE E3board ECADLM 7.000 permanent uncounted 5789B6641A42 \
FEATURE E3cable_sb_to_prof ECADLM 7.000 permanent uncounted \
1FC5D7EE7CE2 VENDOR_STRING=PENGRUBIN HOSTID=ANY TS_OK
FEATURE E3cable_sb ECADLM 7.000 permanent uncounted 32E2A8E78C52 \
FEATURE E3cable ECADLM 7.000 permanent uncounted FC2625CDF582 \
FEATURE E3caddyBasic ECADLM 7.000 permanent uncounted DB0CBF33D03F \
FEATURE E3caddyEconomy ECADLM 7.000 permanent uncounted 3200348D818A \
FEATURE E3caddyProfessional ECADLM 7.000 permanent uncounted \
A3FF70DC8502 VENDOR_STRING=PENGRUBIN HOSTID=ANY TS_OK
FEATURE E3exportEXF ECADLM 7.000 permanent uncounted A6AA640F0541 \
FEATURE E3logic ECADLM 7.000 permanent uncounted D58B638725BF \
FEATURE E3panel ECADLM 7.000 permanent uncounted 4E7554BE7964 \
FEATURE E3pdf ECADLM 7.000 permanent uncounted 52E49DAFDF24 \
FEATURE E3redliner ECADLM 7.000 permanent uncounted 5280D103D55C \
FEATURE E3schema_sb_to_prof ECADLM 7.000 permanent uncounted \
25AF627FD751 VENDOR_STRING=PENGRUBIN HOSTID=ANY TS_OK
FEATURE E3schema_sb ECADLM 7.000 permanent uncounted 85473859C9BB \
FEATURE E3schema ECADLM 7.000 permanent uncounted 3413A94D4847 \
FEATURE E3schema_to_cable ECADLM 7.000 permanent uncounted \
E43DD8D25F6A VENDOR_STRING=PENGRUBIN HOSTID=ANY TS_OK
FEATURE E3student ECADLM 7.000 permanent uncounted 900D77C8C5C1 \
FEATURE E3view ECADLM 7.000 permanent uncounted D2EC2789511F \
FEATURE E3viewPlus ECADLM 7.000 permanent uncounted 169FEDC700AC \
FEATURE E3wire ECADLM 7.000 permanent uncounted D1E72B71D8C2 \
FEATURE Plus ECADLM 7.000 permanent uncounted F673C558A75A \
FEATURE dfb ECADLM 7.000 permanent uncounted 1B46E7D52663 \
FEATURE eco ECADLM 7.000 permanent uncounted BD2C92DD38ED \
FEATURE frs ECADLM 7.000 permanent uncounted 9171A101394C \
FEATURE multiuser ECADLM 7.000 permanent uncounted 49749310F015 \
FEATURE wireLINK ECADLM 7.000 permanent uncounted 1011D5A67EC8 \
FEATURE E3sap-bom ECADLM 7.000 permanent uncounted 77DA3FB1E592 \
FEATURE E3sap-mat ECADLM 7.000 permanent uncounted 3B390F884283 \
FEATURE E3sap-dms ECADLM 7.000 permanent uncounted D2008B61CBF6 \
FEATURE E3_SolidEdge ECADLM 7.000 permanent uncounted 2125C16D4827 \
FEATURE E3_CATIA_V5 ECADLM 7.000 permanent uncounted 727F27F38628 \
FEATURE E3_ProE ECADLM 7.000 permanent uncounted A3701F784B37 \
FEATURE E3formboard ECADLM 7.000 permanent uncounted DA1D843D9AC4 \
FEATURE E3avionics ECADLM 7.000 permanent uncounted E6A5EB37494D \
FEATURE E3cgm ECADLM 7.000 permanent uncounted BCD229FE6BA4 \
FEATURE E3_MIL_Standard ECADLM 7.000 permanent uncounted B9226271A241 \
FEATURE E3_STEP_AP212_ELOG ECADLM 7.000 permanent uncounted \
7FB8ABFD80A0 VENDOR_STRING=PENGRUBIN HOSTID=ANY TS_OK
FEATURE E3_STEP_AP212_KBL ECADLM 7.000 permanent uncounted \
7534A9536D5F VENDOR_STRING=PENGRUBIN HOSTID=ANY TS_OK
PDLFFALF wrote:把如下内容复制到一个文本文件里改名为license.dat后再复制到:
TS_OK
Friends, Hello!
Application of the authorized production of PDF files will appear wrong, hoping to get help, thank you! !
朋友,你好!
应用该授权制作PDF文件时会出现错误,希望能够得到帮助,谢谢!!!
====== CoMod wrote ===========
Please to use http://translate.google.com/translate
