[?]: How transfer licence to TP177B PN/DP ?
krcedinac
Post by krcedinac »
Hello to all
How to transfer licence key to the Tp177 PN/DP panel.
I never had to do it until now.
When I try to use ALM it says that it needs to be installed on the target PC (panel) and also I can not see it (panel) on my LAN althought that Smart Acces is working.
Thanks in advance
krcedinac
Post by krcedinac »
Hello CoMod,
Thanks for answering. I use WinCCFlex 2007 Advanced and ALM 3.0.I tried to transfer the key both with Ethernet and MPI/DP and I get same message.
I know for sure that both Ethernet and Profibus are working and both adreses are good. I do not know what is wrong.
I decided to try one last time and it worked like a charm although I did not change anything.
Regards
I also viewed this message... because I have installed new Flex2008 and ALM4
1. Need update Panel OS to your actual Flex version
2. Set adress MPI/Profibus and Enable Remote control in Panel.
I have transfered my key after 1,2.
