[?+]: protool v6 sp3 not connection to op17-dp
crack_x01
Post by crack_x01 » Thu Oct 23, 2008 7:16 am
hi all friends
How is an OP17-dp connected for the serial transfer of the configuration to the configuration PC?
I tryed MPI cable but not connection.
best regards
dibolo
Post by dibolo » Thu Oct 23, 2008 8:20 am
crack_x01
Post by crack_x01 » Fri Oct 24, 2008 9:21 pm
hi friend
OP17 startup screen;
turn off op17 and i am waiting
after turn on and esc+cursor down+ cursor right
wait wait wait :( and no connection. i have standart cable.
best regards
Titus
Post by Titus » Mon Feb 16, 2009 8:55 pm
at first you have to use SUB-D 9 (socket) ---- SUB-D 15 (connector) cable. After that your OP must be in transfer mode, for transfer mode key combination please look to OP7-17 manual.
crack_x01
Post by crack_x01 » Mon Feb 23, 2009 10:28 pm
Titus wrote:at first you have to use SUB-D 9 (socket) ---- SUB-D 15 (connector) cable. After that your OP must be in transfer mode, for transfer mode key combination please look to OP7-17 manual.
My problem was solved.keys were defective.
bestrgards
