[Scheme]: Trend-Controller IQ3XCITE
другие контроллеры
FLETCHER
Post by FLETCHER » Fri Oct 17, 2008 11:58 am
Trend-Controller IQ3XCITE with software set 6.
I'm trying to download one program to this controller with lan connection.
I set up the addres IP and it responds ok to ping with crossover cable, but i cannon download or upload nothing the connection fails all time.
Is needed the serial cable rj11-db9 for made this?
I agree some help with the connection support.
Thanks.
vlad2006gr
Post by vlad2006gr » Fri Oct 17, 2008 1:10 pm
For RJ11 - DB9 ADAPTOR see http://www.jdstechnologies.com/download ... pinout.pdf
Good luck!
FLETCHER
Post by FLETCHER » Mon Oct 20, 2008 7:09 am
Thanks for your suport.
But are you sure that is the same schema for trend controls.
vlad2006gr
Post by vlad2006gr » Mon Oct 20, 2008 8:17 am
Trend-Controller IQ3XCITE has standard EIA-232 port
See http://ntc.novarcontrols.com/Products/I ... 3XCITE.pdf
and http://www.rkg.cz/uploaded_files/ke_sta ... ite_aj.pdf
RJ11 for IQ3XCITE :
1 RX
2 +24v
3 CTS
4 RTS
5 0v
6 TX
Good luck!
FLETCHER
Post by FLETCHER » Mon Oct 20, 2008 10:36 am
Is this I assembly it now and I tell You something.
Is not rj11 is rj12
FLETCHER
Post by FLETCHER » Mon Oct 20, 2008 1:03 pm
The solution is in the last picture it works ok.
Thanks.
thermal
Trend IQ3xcite RS232
Post by thermal » Sat Jun 06, 2009 12:20 am
I know this is a long time back now:
the datasheet listed above, table at bottom of page 18 says only text comms via 232, not download.
This is also on page 24 of latest datasheet.
Interested to know if you did get it to communicate enough.
Do you not have SET programme & product key?
we need a friendly in here to crack SET :)
autogeek
Re: [Scheme]: Trend-Controller IQ3XCITE
Post by autogeek » Fri Aug 28, 2009 6:29 am
I am looking for a copy of the SET6 software? can you help me? where do you find it?
Thanks!
saad rashed
Post by saad rashed » Thu Feb 04, 2010 8:48 pm
MY DEARS I NEED THE SOFT SET 6.X
THANKS ALOT
caspyro
Post by caspyro » Tue Apr 11, 2017 7:21 pm
hi did any one ever get SET software ?
caspyro
Post by caspyro » Mon Feb 11, 2019 10:14 pm
hi i now have two versions of SET but no registration if any one want to hav a go with it and gets it working let me know
https://mega.nz/#!vrxU3A4T!NvSdgPuhsT-O ... 4Spq3Bbz04
caspyro
Post by caspyro » Mon Feb 11, 2019 10:15 pm
