[?]: How save project to CF without HMI device ?
landey
Post by landey » Fri Sep 12, 2008 7:04 pm
There is a problem, I don't know how or is it possible to solve:
How to save wincc flexible project from PG to memory card CF/USB (like during operation Backup/Restore) without HMI device.?
It's easy if you have HMI device.
But... if not?
It's necessary if you need to make project update and HMI device is no available (you are in office and device is on site, far away)
dm1dm2
Post by dm1dm2 » Mon Nov 03, 2008 10:45 pm
I have done it before by first copying compiling and running the project on my PC.
Then plug CF card with existing project into laptop and browse it with windows explorer to see whaich project files are on the card - it was a long time ago,
so I can't remember which directory was required.
Then copy the compiled runtime files off your PC to the same folder on the CF card.
