[?]: MP370 connectivity to TTY submodule at S5 CPU928B
ichigosakuragi
Post by ichigosakuragi » Wed Sep 10, 2008 5:41 am
Hello everyone
the TTY submodule port on si2 used to connect to OP37 using open drive protocol in DX2 and DX3 in program on the PLC.
They used the FAP protocol on the Protool for the configuration of the HMI.
it is the original seeting of the system.
Im trying to replace it by MP370 with AS511 protocol
but when i connect it to the TTY submodule on the IF1A on the MP370 it still not working or IF1A broken pop up on the HMI.
Is there a possibilty to connect the MP370 to the TTY sub module or something to have done on the program or do we have to use the SI1 PG port to connect it.
If the SI1 PG port will be used what will be the steps or added program to be done on the PLC
