[LINK]: How unprotect DFB in Concept ?
другие контроллеры
xz739
Post by xz739 » Mon Aug 25, 2008 2:24 am
i want to modify the logic of a DFB in Concept 2.6,
but it is been protected by concept security,
its need a password that i dont konw,
anybody could help me?
thanks
Schtiel
Post by Schtiel » Tue Aug 26, 2008 11:10 am
Upload your DFB somewhere. I'll have a look.
xz739
Post by xz739 » Thu Aug 28, 2008 1:15 am
RomanR
Post by RomanR » Sun Aug 31, 2008 4:49 am
Iam Think You cant chenge you DFB witout password
ak68
Re:
Post by ak68 » Wed Jun 23, 2010 3:42 pm
Hi, you could get any help on this? how to recover dfb with lost password?
Link
Forum Community
Forum Community
Contact:
Re: [LINK]: How unprotect DFB in Concept ?
Post by Link » Wed Jun 23, 2010 5:26 pm
Concept 2.6
Encrypted DFB
1Open in WinHex file DFB
project / DFB / name_DFB.P4
Back at offset 9B1. In the closed block format string will be:
FF FF FF FF 61 D3 72 09.
Где FF FF FF FF- indicator that the unit is closed.
In an open block- 00 00 00 00.
61 D3 72 09- encrypted password.
These values (61 D3 72 09) replaced by E6 05 46 39,
password is 000000.
Or 76 F3 18 18 - Password: 111111.
Russian wrote:1Открыть в редакторе WinHex запароленный файл ДФБ по пути
project / DFB / название_дфб.P4
Перейти по адресу offset 9B1. В закрытом блоке формат строки будет:
Где FF FF FF FF- указатель , что блок закрыт. В открытом блоке- 00 00 00 00.
61 D3 72 09- зашифрованный пароль. Эти значения (61 D3 72 09) заменить на E6 05 46 39,
пароль будет 000000. Или 76 F3 18 18- пароль 111111.
2Opening of the project, if locked with a password.
Open in editor WinHex locked file DFB on the way
project / title.R4
Go to the address offset 8BC. When closed, the draft format of the string will be:
The values of 61 D3 72 09 replaced in on E6 05 46 39 password will be 000000.
Russian wrote:2Открытие проекта, если закрыт паролем.
project / название_проекта.Р4
Перейти по адресу offset 8BC. В закрытом проекте формат строки будет:
Значения 61 D3 72 09 заменить на E6 05 46 39, пароль будет 000000.
Good luck!
ak68
Post by ak68 » Thu Jun 24, 2010 7:31 pm
Good work, Thanks a lot :D
annlumia
Post by annlumia » Fri Nov 15, 2019 12:30 am
