[LINK]: WinCC Flexible 2008 + SP3 + SP5 for Windows 7/10
Link
Forum Community
Forum Community
Post by Link »
WinCC Flexible 2008 Multilanguage (with ASIA/China)
(mirr) https://disk.yandex.ru/d/HIJCwCiixE3Uxw
Released for Delivery
http://support.automation.siemens.com/W ... n/29735640
What's New (English)
https://support.automation.siemens.com/ ... ewenUS.pdf
Die neuen Funktionalitäten von WinCC flexible 2008 (Deutsch)
https://support.automation.siemens.com/ ... ewdeDE.pdf
New
increased to 4096 Powertags
New RT license: SISLA9XRP40103.EKB "WinCC flexible 2008 Runtime (4096)"
EKB_Install_2008_08_20 wrote:add only new Flex2008 keys to EKB_Install_2008_08_20
for options need use old keys
● Raised system limit to support 4096 tags on MP 377
Supported OS:
Microsoft Windows XP SP3/SP2
Microsoft Windows Vista Business (32 Bit), Ultimate (32 Bit) - NOT SP1 !
WinCC Flexible 2008
viewtopic.php?f=30&t=218
Cumulative THANKS for uploader and Siemens Flex group
No need add new "Thanks Again"
Demo projects for SIMATIC Panels
http://support.automation.siemens.com/W ... n/22900091
WinCC flexible 2008 SP4 China for Smart Line 1000 and 700
viewtopic.php?f=36&t=18050&p=54152&hili ... ina#p54152
leewheel
Post by leewheel »
3 versions in torrent
Siemens SIMATIC WinCC Flexible 2008 http://rutracker.org/forum/viewtopic.php?t=1249421
Siemens SIMATIC WinCC Flexible 2008 SP3 http://rutracker.org/forum/viewtopic.php?t=3957237
Siemens SIMATIC WinCC Flexible 2008 SP2 (Full DVD) http://rutracker.org/forum/viewtopic.php?t=3007619
direct link for torrent client
[dead] :/45225C09E4F ... 7094603AF6
Info
Faq & Info
Faq & Info
Post by Info »
FAQ: Why can't you install the SQL server from WinCC V6.2 or WinCC V6.2 SP2 after installing WinCC flexible 2008?
http://support.automation.siemens.com/W ... n/30576253
Remedy:
You can only install the SQL server from WinCC V6.2 or WinCC V6.2 SP2 if the WinCC flexible instance of the Microsoft SQL Server 2005 Express Edition was deinstalled.
WinCC flexible 2008 does not have to be deinstalled.
Procedure:
1. deinstal Microsoft SQL Server 2005 Express Edition
2. Install WinCC V6.2 or WinCC V6.2 SP2
3. Start the "Setup.exe" file on the product DVD of WinCC flexible 2008 and execute the installation.
Update
Forum Community
Forum Community
Post by Update »
Hotfix 3 for WinCC flexible 2008
http://support.automation.siemens.com/W ... n/31796860
Problems corrected in Hotfix 3
Show
Problems resolved and optimization of configuration scenarios with this hotfix:
● The Reset bit is not reliably executed for the following HMI devices:
– OP 73
– OP 73micro
– OP 77A
– TP 177A
– TP 177micro
– Basic Panels
● The opening times for screens on the TP 177A und TP 177micro have increased with
WinCC flexible 2008.
● The hour glass is not shown when changing screens on the TP 177A and TP 177micro
HMI devices. This can result in malfunctions.
● No "Bit" data type tags should be configured in the "R" area on the OP 77A, TP 177A and
Basic Panels with Allen Bradley DF1, because incorrect values may occur.
● Sporadical interrupts of connection with TP 177micro.
Hotfix 2 for WinCC flexible 2008
http://support.automation.siemens.com/W ... 08_HF2.exe
Problems corrected in Hotfix 2
Show
This hotfix corrects the following problems in the engineering system and optimizes configuration scenarios:
● Instance update of faceplates
Some changes do not require an instance update of faceplates.
● Errors during compilation
Deriving an instance from faceplates with formatted text results in errors during compiling.
● Error with dragging and dropping faceplates from a library
● Problems updating faceplates
Using formatted text in faceplates results in errors when updating these faceplates.
● Using "Undo" and "Redo" on faceplates with formatted text and structures results in corruption.
● Errors during STEP 7 synchronization
If you replace a CPU with another that has a different revision level, STEP7
synchronization may not function correctly.
● SIMOTION projects cannot be opened
In some circumstances, HMI projects created with WinCC flexible 2007 cannot be opened in SIMOTION.
● Problems with DEMO mode
No DEMO mode after removing valid compact keys.
● Error installing MSDE
● Error message when closing WinCC flexible
If the last action you perform in WinCC flexible is changing the visibility of layers, an error message appears when you close WinCC flexible.
● Canceling "Save as version"
Depending on the computer load, "Save as version" cancels without results.
● Save as version without administrator rights
If you do configuration work without administrator rights, you cannot use "Save as version".
● Internal error
If you delete a trend display that contains routing tags, internal errors occur.
● Illegal array lengths with TP177 6" and TP177 6" portrait devices
● USB PPI cable 6ES7901-3DB30-0XA0 as of Version 06
The "Reset to default settings" fails with the following HMI devices:
– Mobile Panel 277
– MP 277
– Mobile Panel 177 DP
– Mobile Panel 177 PN
– Mobile Panel 277
– TP 177B (without TP 177B 4")
– OP 177B
– TP 277
– OP 277
– MP 177
– TP170A
– TP170micro
This hotfix corrects the following problems in Runtime and optimizes its performance:
● After stopping Runtime and restarting the device, the last language to which you switched is no longer active.
You have transferred a project to an HMI device and switched to a different configured language.
You then stop Runtime and restart the HMI device.
When the HMI device has started and is ready to operate, the language to which you last switched is no longer active.
All CE devices are affected
● After WinCC flexible Runtime 2008 has been removed, some ActiveX applications (for example, Automation License Manager) may no longer run correctly.
Note
It is imperative that the hotfix be installed before WinCC flexible Runtime 2008 is removed.
● Text fields are displayed truncated.
When you convert projects from WinCC flexible 2007 to WinCC flexible 2008, configured text fields may be shown truncated in Runtime, if the "Adapt utomatically" option is disabled
Hotfix 1 for WinCC flexible 2008
http://support.automation.siemens.com/W ... 08_HF1.exe
( 19486 KB )
It is obligatory if you want use examples from official site.
Hotfix 1
Show
● Error converting project.
If you convert a project from a previous version to WinCC flexible 2008, the conversion
may fail.
● Defective faceplates after project conversion.
If you convert a project from a previous version to WinCC flexible 2008, individual
faceplates may be defective after project conversion.
Russian wrote:Настоятельно рекомендуется установить это обновление,
если у вас есть желание запускать примеры от прежних версий, выложенные на официальном сайте.
Иначе возможны проблемы вплоть до Синего Экрана Смерти = BSOD
Link
Forum Community
Forum Community
Post by Link »
Update
Forum Community
Forum Community
Hotfix 1 for WinCC flexible 2008 Service Pack 1
Post by Update »
Hotfix 5 for WinCC flexible 2008 Service Pack 1
Hotfix 5
Show
http://support.automation.siemens.com/WW/view/en/36540041
Hotfix 3 for WinCC Flexible 2008 SP1
https://support.automation.siemens.com/WW/llisapi.dll/csfetch/36540041/WinCCflexible2008_SP1HF3.exe
This hotfix solves the following problems in Runtime and optimizes configuration scenarios:
● Restart of HMI device or exiting the simulation
The screen change from recipe view can result in a restart of the HMI device in some HMI
devices.
Certain configurations during simulation of HMI devices can exit the simulation.
Devices affected:
– OP 77A
– TP 177A
– KTP 178
– KTP400 Basic
– KTP600 Basic
– KTP1000 Basic
– TP1500 Basic
Hotfix 2 for WinCC Flexible 2008 SP1
https://support.automation.siemens.com/WW/llisapi.dll/csfetch/36540041/WinCCflexible2008_SP1HF2.exe
( 72853 KB )
● Incorrect display of graphical elements
If you work with many graphical elements in WinCC flexible, the graphical elements are no longer displayed correctly.
● Error message while compiling
You will see the following error message during compilation of a comprehensive WinCC flexible project:
"The WinCC flexible Engineering System does not have sufficient memory to continue and must be shut down. Close all unnecessary applications and restart the
WinCC flexible Engineering System."
● Failed project transfer
If you have compiled a project with WinCC flexible Service Pack 1, it can no longer be transferred to the HMI device. The compiled project file ".fwx" is too large.
https://support.automation.siemens.com/WW/llisapi.dll/csfetch/36540041/WinCCflexible2008_SP1HF1.exe
( 72694 KB )
Problems corrected in Hotfix 1 wrote:This hotfix corrects the following problems in the engineering system and optimizes configuration
scenarios:
● Internal compiler error with tags with linked animations.
If an error occurs with tags with linked animations, the affected location is displayed.
● Conversion error opening projects created prior to WinCC flexible 2008 SP1.
Events at a tag with array elements are deleted during conversion.
● Incorrect references after conversion of projects created prior to WinCC flexible 2008 SP1.
The events at a tag with array elements deleted as a result of the conversion error are restored.
If you have configured a new event in a project that has already been converted, the old incorrect reference is deleted.
The affected tags are logged in the output window in either case.
● Long compile times in projects with numerous faceplate instances.
Runtime problems resolved and optimization of configuration scenarios with this hotfix:
● The "Transparent color" setting does not work on the "Graphic view" screen object on the
– OP 270
– TP 270
– MP 270
– C7-636
● Touch operation is not detected.
Touch operation is sporadically not detected on the following HMI devices:
– TP 177 4"
– OP 177B
– TP 177B
– TP 277
– Mobile Panel 177
– Mobile Panel 277, Mobile Panel 277 IWLAN
– MP 177
– MP 277
– MP 377
● The sound does not work on some of the HMI devices of the MP 377 series.
Add new images for fix problems.
Answers to FAQs
Faq & Info
Faq & Info
Re: Installation problem
Post by Answers to FAQs »
slinky wrote:I have a problem when installing.
'Cannot create database' error when starting to install flex 2008.
Initially I had lots of problems installing .NET and SQL server, but they are installed OK now.
http://support.automation.siemens.com/W ... n/29420407
RubberDuck
Re: [LINK]: WinCC Flexible 2008 + SP1 + HF3
Post by RubberDuck »
It's working
RubberDuck
Link
Forum Community
Forum Community
Post by Link »
Demo projects for SIMATIC Panels (WinCC flexible 2008/STEP 7 Basic V10.5), Panel PC and WinCC flexible PC Runtime
Date: 2010-01-14
Link
Forum Community
Forum Community
Re: [LINK]: WinCC Flexible 2008 + SP2
Post by Link »
WinCC flexible 2008 SP2
WinCC Flexible 2008 with SP2
Full DVD 3.6 GB
Torrent link http://rutracker.org/forum/viewtopic.ph ... 3#35797163
or
https://mega.co.nz/#F!2Rd0Ga5C!eB68tI3Qp6ep02jCUP6P8w
Password is: flex2008SP2
Download only SP2 for WinCC Flexible 2008
http://support.automation.siemens.com/W ... n/38612895
https://support.automation.siemens.com/ ... 08_SP2.zip
1.5 GB
About
http://support.automation.siemens.com/W ... n/38612975
What's new in WinCC flexible 2008 SP2?
Show
Support for Microsoft Windows 7
WinCC flexible with Step7 Integration under Windows 7
SIMATIC Step7 V5.4 is not released for the operating system Microsoft Windows 7. It therefore is not possible to use WinCC flexible and Step7 in the integrated mode under Windows 7. For this a separate release will be carried out at a later time
2. New Functionality
Engineering and usability
● New menu command for clearing the list of most recently opened projects
● Object view shows additional information
– Tag comments
– Recipe number
Widescreen for PC Runtime
* 1440 x 900, 1680 x 1050, 1920 x 1080, 1920 x 1200
Enhancements for the Basic Panels
* new System functions
+ set Bit in Tag
+ reset Bit in Tag
+ invert Bit in Tag
* Retentive message buffer
* Number of configurable Tags
o KTP400 Basic: 250
o KTP600 Basic: 500
o KTP1000 Basic: 500
o TP1500 Basic: 500
* new communication driver
o Modicon Modbus TCP/IP
o Mitsubishi FX
o Omron Hostlink/Multilink
Sm@rtService/Sm@rtAccess
* reduced CPU-utilization due to Sm@rtServer
* automatic scaling between server and client
* improved usability in configuration dialogs
Support of new devices
ALM v5.0 - add support Windows 7.
Tested - Ok.
Link
Forum Community
Forum Community
Post by Link »
jahman wrote:After installing SP2 ALM shows me 4 missing keys( I have used Simatic_EKB_Install_2010_03_20, maybe there is a newer one).
The missing keys:
Family-----------------------------Product--------------------------Version
SIMATIC HMI-------------WinCC flexible /Audit for PC--------------1.3
SIMATIC HMI-------------WinCC flexible /Recipes for PC-----------1.3
SIMATIC HMI-------------WinCC flexible /OPC-Server for PC-------1.3
SIMATIC HMI-------------WinCC flexible /Sm@rtAccess for PC-----1.3
EKB install has only Version 1.0. WinCCFlexible is running but maybe there some parts which doesnt work without these keys.
for testing Simatic_EKB_Install_2010_05_09.zip
wait report
! all previous versions may fail if the installed the new version of the ALM v5 keys - type v5!
error will be corrected in future versions.
Because of the new release ALM v5 may be many intermediate versions as far as finding new challenges.
! у всех предыдущих версий возможна ошибка, если на диске установлены ключи нового ALM v5 :(
ошибка будет устранена в следующих версиях.
В связи с выходом новой версии ALM v5 возможно будет много промежуточных версий по мере нахождения новых проблем.
marek_gabriel
Post by marek_gabriel »
Dear friends,
some of my collegues have installed Flex2008 + SP2 while I stayed at SP1 + HF5. It looks fine and works perfectly, but it seems the projects are not compatible, other guys can open mine, but I cannot open theirs. IF it's true then we have a problem... Un-documented, of course.
I wonder if anyone else has the same experience or can post a link.
problems
Show
marek_gabriel wrote:Dear friends,
Flex2008 SP2 use new database engine
for this it convert old Flex2008 SP1 project to new database
[dead]
Use Save as...
[dead]
Bugs
Invalid polygons in Editor mode
Russian forum wrote:Впечатления от СП2, неприятные
0. Открыл проект из СП1 и певрое, что бросилось в глаза - рваные линии полигонов - стал разбираться, ведь в СП1 это же выглядело нормально.
1. Такое впечатление, что графический редактор глючит - очень трудно добиться видимости всех вертикальных/горизонтальных линий полигонов в режиме Редактора,
при этом они отображаются в режиме Runtime.
2. Второй раз выскочило пугающее предупреждение во время нажатия правой кнопки на группе выделенных примитивов для вызова всплывающего меню.
К счастью не катастрофичное - программа после "Ок"нормально работает дальше.
[dead]
No one side of polygon in Editor mode. In Runtime all Ok.
Group gluck
[dead]
Link
Forum Community
Forum Community
Post by Link »
Full DVD 3.6 GB ISO image
Image Torrent link http://rutracker.org/forum/viewtopic.ph ... 3#35797163
33*100.000.000 + 81.616.563 bytes
Update13 for WinCC flexible 2008 SP2 (HotFix 13 include ALL previous Update 1.. 12)
(sdown)
http://support.automation.siemens.com/W ... n/43412059
https://support.automation.siemens.com/ ... 2Upd13.zip
108 MB
verticale128
Post by verticale128 »
benthouse wrote:Anybody who has an english torrent link available?
Service http://translate.google.com for view russian/chinese pages
http://translate.google.com/translate?h ... %3D3007619
It would be very useful for me too!!
Thanx
Oldman
Re: [LINK]: WinCC Flexible 2008 + SP2 + Update 3
Post by Oldman »
Demo projects for HMI Panels at WinCC (TIA Portal) for Basic Panels, Comfort Panels and WinCC Runtime Advanced (TIA Portal)
http://support.automation.siemens.com/W ... n/50599077
SIMATIC HMI WinCC flexible 2008 Getting Started - First-Time Users
http://support.automation.siemens.com/W ... n/18660846
Gauge Controls for Basic Panels.
http://support.automation.siemens.com/W ... n/48052573
Link
Forum Community
Forum Community
Post by Link »
WinCC Flexible 2008 with SP3 for XP32 and W7 32/64 / EURO+ASIA
About http://support.automation.siemens.com/W ... n/57267466
SIMATIC WinCC flexible 2008 SP3 TRIAL Download (sdown)
http://support.automation.siemens.com/W ... /100777999
TRIAL = FULL version
TRIAL = ПОЛНАЯ версия
WinCC flexible 2008 SP3 Update5
http://support.automation.siemens.com/W ... n/58860033
https://mega.co.nz/#F!nQUUEQLR!ONJao5tj02dy4BuGsQuqxg
Torrent
RapidShare Package: [dead]
Update
Forum Community
Forum Community
Re: [LINK]: WinCC Flexible 2008 + SP3 + HF2
Post by Update »
Answers to FAQs
Faq & Info
Faq & Info
SHKODRAN wrote:I have installed this version , everything is working very well , but I don't find the "Migration" tool installed?
Wincc installation is finished correctly , without any problem!
How I can convert Protool 6.03 project to this Wnicc 2008?
ReRead about http://support.automation.siemens.com/W ... n/57267466
about ProTool Migration wrote:ProTool Migration:
Because of the neccessary changes for the 64 Bit support under Windows 7, the ProTool migration cannot be offered any more with Service Pack 3 for WinCC flexible 2008.
Install WinCC flexible 2008 SP2 on VirtualBox.org and use Migration (h)
Update
Forum Community
Forum Community
Re: [LINK]: WinCC Flexible 2008 + SP3 + HF3
Post by Update »
Update3 for WinCC flexible 2008 Service Pack 3
Rex2701
[Update]: WinCC Flexible 2008 + SP3 + HF4
Post by Rex2701 »
Coyote
Re: [LINK]: WinCC Flexible 2008 + SP3 + HF4
Post by Coyote »
Is it possible to get Service pack 3 for wincc flex 2008 alone? I have Winccflex 2008 SP2 already installed and I would like to upgrade existing installation.
Thanks.
Re: [LINK]: WinCC Flexible 2008 + SP3 + HF5
guzo007 wrote:hi all
the download links dont work!
can i have please a new link to download wincc flexible sp3 und crack?
please help me
all link ?
optimal to use torrent http://rutracker.org/forum/viewtopic.php?t=3957237
or send private request in Private Message for private link to Mega
anti-abuse firewall (h)
Update
Forum Community
Forum Community
Post by Update »
salphonse
Post by salphonse »
Coyote wrote:Is it possible to get Service pack 3 for wincc flex 2008 alone? I have Winccflex 2008 SP2 already installed and I would like to upgrade existing installation.
Thanks.
Hi Did you get the Service pack 3 file alone. I am also looking for the same.
Coyote
Post by Coyote »
I didn't. I had installed wincclfex 2008 SP3. It has sensed that SP2 is installed, then it removed winccflex, reboot the PC and it installed SP3. Thanks god there were no problems and now it works with SP3.
Tomekk
Post by Tomekk »
Link wrote:WinCC Flexible 2008 with SP2
WinCC_flex_2008_SP2.part04.rar: Checksum error in the encrypted file WinCC_flex_2008_SP2.iso. Corrupt file or wrong password.
hmhmat
Post by hmhmat »
nope everything okay the password was wrong it is :flex2008SP2
Good luck
Update
Forum Community
Forum Community
Re: [LINK]: WinCC Flexible 2008 + SP3 + HF7
Post by Update »
Update7 for WinCC flexible 2008 Service Pack 3
https://support.industry.siemens.com/cs ... ti=0&dl=en
Link
Forum Community
Forum Community
Re: [LINK]: WinCC Flexible 2008 + SP3 + SP5 for Windows 7/10
Post by Link »
SIMATIC WinCC flexible 2008 SP5 TRIAL Download is available.
(pm) (suc) (thnx) (tyou)
(sdown) https://support.industry.siemens.com/cs ... l-download
(sdoc) https://support.industry.siemens.com/cs ... xible-2008
WinCC flexible 2008 SP5 supports the following Operating Systems
Engineering System:
Windows 7 (32 Bit, 64 Bit)
Windows 7 Ultimate/Enterprise SP1
Windows 7 Professional SP1
Windows 10 (64 Bit)
Windows 10 Professional
Windows 10 Enterprise
Windows 10 LTSB Enterprise
Runtime System:
Windows 7 Embedded Standard (32 Bit) *)
Windows 7 Embedded Standard mit SP1 (32 Bit) *)
Windows 10 (64 Bit)
Windows 10 IoT LTSB Enterprise *)
The license keys from WinCC flexible 2008, 2008 SP1/SP2/SP3 can be used without any change for WinCC flexible 2008 SP5 too.
Update
Forum Community
Forum Community
Post by Update »
Link
Forum Community
Forum Community
Post by Link »
I need the two exe files from the Trial download.
SIMATIC_WinCC_flexible_2008_SP5_CSA.exe (2,7 MB)
SIMATIC_WinCC_flexible_2008_SP5_Runtime.exe (2,7 MB)
No torrent download links.
exe only packed to ZIP
https://mega.nz/#F!MCBTiJqK!5OY1PRyqHZn-hm7FPlzMJg
Corosop15
Post by Corosop15 »
Thank you very much.
Greatings and I wish you a nice weekend....
Corosop15
WinCC Flexible 2008 SP5 have new format incompatible with WinCC Flexible 2008 SP3 (boom) (h)
WinCC Flexible 2008 SP5 имеет новый формат несовместимый с WinCC Flexible 2008 SP3
lessat
Post by lessat »
hmhmat wrote:nope everything okay the password was wrong it is :flex2008SP2
Good luck
Thank you!!! (tyou) (tyou) (tyou) (tyou) (thnx)
maike2006
Post by maike2006 »
Any solution for above problem ?
i got this message and i think it's related to same above problem
WinCC flexible / Sm@rtService for PC-RT and WinCC flexible / Sm@rtAccess for PC-RT
i checked last Sim_EKB_Install
License manager
Image dead [dead]
(installed all 3333 keys)
Info
Faq & Info
Faq & Info
Post by Info »
:anon: ReRead Help file - no need install ALL keys !!!
:anon: Install only 1 required key for option with major version number
(sfaq) How can you deactivate the Trial License when the message appears indicating that the Trial License has expired, although the Floating License has been installed?
https://support.industry.siemens.com/cs ... t/24200966
365electricalvn
Post by 365electricalvn »
Update (Hotfix) for WinCC flexible 2008 Service Pack 5
https://support.industry.siemens.com/cs ... 0&lc=de-WW
Please, help me download it. I registered member but can not download :(
Thanks you so much.
Update
Forum Community
Forum Community
Post by Update »
https://mega.nz/#F!iGIhwYqD!jErvHTSzl6oaK6Rv06uGQw
Update
Forum Community
Forum Community
Post by Update »
Update 2 (04/2020) for WinCC flexible 2008 Service Pack 5
(sdown) https://support.industry.siemens.com/cs ... /109757233
pacotabaco
Post by pacotabaco »
Hey guys! I do not want to disturb you, but it seems the WinCC Flexible 2008 link is down...
Would someone be able to reupload it? I need to install SP2 to make a protool migration but it is impossible to find a working link...
Thanks to yall!
it Live = rutracker and Mega
viewtopic.php?f=4&t=8650&p=92608#p35717
pacotabaco
But is it sp0 + sp2? Or sp2?
I got sp2, i need sp0 to install it before sp2...
Thanks in advance!
(rr) reRead Full !!! (h)
pacotabaco
You are right! It works fine.
Thanks (thnx)
pavalevlad
Post by pavalevlad »
Hello.
Please give a link to download "Update 2 for WinCC flexible 2008 SP5".
I can't download from the Siemens website.
Link
Forum Community
Forum Community
Post by Link »
POV_PDA
Post by POV_PDA »
What the file "Patch_STEP7_V5.7_Integrity.zip"
under https://support.industry.siemens.com/cs ... 9&lc=hu-HU
please download siemens - upload yandex
Thanks.
Update
Forum Community
Forum Community
Post by Update »
POV_PDA wrote: Tue Nov 29, 2022 4:44 pm What the file "Patch_STEP7_V5.7_Integrity.zip"
Thanks.
2f6ec88f1e09525f0a18dcda2aa120cbd35b224e6117ccf44d3a1f14c7d20909 *Patch_STEP7_V5.7_Integrity_01.05.00.03_02.01.00.01.zip
If the integrity monitoring in STEP 7 Version 5.7 is activated - ("Menu -> Options-> Settings...-> Application integrity monitoring") - integrated WinCC flexible projects can be used with the patch installed.
https://disk.yandex.ru/d/HIJCwCiixE3Uxw ... 2008%20SP5
https://mega.nz/file/PSpEQQ6B#rdLLFMZJs ... VWZxb0PQYw
https://mega.nz/file/PSpEQQ6B#rdLLFMZJspbxvJ5ByWcFy6HJqYOQKK4TaVWZxb0PQYw
