I m a new user of Omron PLCs. I have a problem with a CPM2A.
I downloaded a program from the PLC using Cx-Programmer i want to install the same program in a second and similar machine with the same PLC that had lost his program.
The problem is that i found 6 errors in compilation of the program that i downloaded : Error STEP in SBN.
I think that it s because of Step operation is not possible in SBN but it s strange that this program is corrertly runnig in the first machine.
Can you help me please. I want to load the program into the second machine.
Thanks.
