[?]: How made Yellow Disk ?
bodemin
Post by bodemin »
I cannot create a yellow disk.
I use Winimage.
In My Computer page I can see the diskette drive but it is empty.
I try to load with my .ima file but I couldnot.
Winimage gives me a warning:
Winimage wrote:"there is no floppy drive" How can I do this?
Could you please type step by step?
I have made these:
1.I installed all license key with EKB.
2.I put the AX NF ZZ folder to diskette drive.
3.I push the create yellow disk button.
What am I doing wrong?
You read viewtopic.php?t=218 ?
You want:
- create new yellow disk ?
- clone Siemens yellow disk ?
Your floppy is cleared from dust ?
bodemin
Post by bodemin »
Yes, I read all of the topic. But it confused me.
I want to crack my WinCC only. I havent any original Siemens floppy disk. I want to use my WinCC without license problem.
You need try with EKB_Install and not Siemens YD.
With PopUp menu you can create an test *.ima file and create new yellow disk with YD button
After this you can read this disk to image file by EKB_Install or WinImage
and Ignore "Bad" track
after this you can try made image of your original disk.
ALL FILES WITH HIDDEN SYSTEM ATTRIBUTE !!!
