Are the WAGO & Beckhoff twincat PLC system the same. For example, is the hardware exhange-able, and need it to be programmed with the same software?
Does anybody has software for the WAGO Etherlink CPU Artnr. 750-842?
Thanks in Advance,
Benthouse
[?]: Are WAGO & Beckhoff PLC the same system?
hello,
software for wago 842 is wago io pro ca lokk there:http://plc.net.ru/viewtopic.php?t=8066&highlight=wago the wago and the beckhoff moduls are at simple things the same, digital in and out, and analog in and out, but special moduls need wago or beckhoff controller.
at the site of wago you can find examples for the 842, to send emails.... and more.
