Nedjeljko
Post
by Nedjeljko » Sun May 04, 2008 2:41 pm
Hi to all.
I have one problem with WinCC Flex 2007, or maybe with Step 7 V5.4 SP3 HF1..
...I have couple of objects in wincc flex which not comunicate with instance db in step 7...
Its happend with couple mtor objects, couple step volume controlls blocks...
...so I must to take the data DB to be interface between Instance db and tag in wincc flex...is very strange whats happend...
can anyone help me or just comment this situation...
Contact:
Post
by CoMod » Sun May 04, 2008 3:14 pm
You can place example of your project ?
Nedjeljko
Post
by Nedjeljko » Sun May 04, 2008 7:17 pm
...Im sendet link for my problematic project...but this is not happend just on this project...I have same problems in couple of them.
Maybe I must to take last HFs for winCC..btw which is last HF for WinCC2007!??!
...so coMod..if you help me I will thankfull
rataman
Post
by rataman » Sun May 04, 2008 8:53 pm
install hotfix for wincc flex, it happened to me.
Nedjeljko
Post
by Nedjeljko » Sun May 04, 2008 8:55 pm
...yea..that I though
..thanks
...which HF is lastone...
Contact:
Post
by CoMod » Mon May 05, 2008 3:19 am
When I start your program PLCSIM wrote multiple DB Arrea length errors.
* spamm have problems - for this possible no picture (russian image hoster)
** need go to work
Nedjeljko
Post
by Nedjeljko » Mon May 05, 2008 10:38 am
..woow...yes I know for this SF...but that happend becouse I been use the old software for the new one, so I have some trash inside...
...this area lenght is in couple FCs...
...that is not my problems...and for shore isnt reason not reading couple instanse DB in WinCC flex..
...or maybe I have wrong...
