[?+]: Reset a Siemens OP3 panel for reprogram
willem de jonge
Post by willem de jonge »
Who knows how i give a OP3 panel a master reset. (factory default).
I want the panel reprogram for another program, but the panel has a password.
I don't know the password, because the panel was used on another machine.
but the password has been changed
Willem
Default password is 100
Rihgt+Down+Esc= Hold and switchON = Delete Configuration & Set Password Default (100)?
willem de jonge
1000x Thanks.
This is the solution. :)
Willem
reymond_craig
Post by reymond_craig »
How about on touch panel is the re a way to reset it to factory defaults?
Thanks,
I do not know, but all there is in mamuals.
