[?]: Modbus TCP S7-200 226 PLC and Wavecom GPRS modem
kelertas
Post by kelertas » Mon Mar 10, 2008 11:25 am
Hello, everybody.
I want to make some project and I want to ask you is this possible and if it so than what method I should choose.
I'm using S7-200 226 PLC and Wavecom GPRS modem.
a) In my PLC I need to establishe internet connection via GPRS modem with AT commands.
b) PLC must be Modbus TCP/IP slave.
Can I communicate via Modbus TCP at all ? Maybe someone has Modbus TCP FBD?
Thank You.
rataman
Post by rataman » Fri Mar 14, 2008 1:34 am
For a s7-200, maybe you can use modbus slave library and a Serial-to-TCP Modbus converter. Like this one:
http://www.intellicom.se/eg_netbiter.shtml
Hope it helps.
