[?]: connecting Starter > S7-315 2DP > MM440
crack_x01
Post by crack_x01 »
hi friends
I want to connect Simatic Starter > S7-300(CPU 315 2DP) > MM440 invertor but not connection.
(PG/PC interface MPI)
pleace help me.
best regards
you can`t connect if you use integral dp-slot & if your cpu NOT 315 2af03,-af83,ag10
it`s work if you use profibus-ext (cp) & parametrise dp-routing
see http://support.automation.siemens.com/W ... en/2383206
crack_x01
Post by crack_x01 »
thank you very much sania
my cpu "6ES7-315-2AF03-0AB0 /V1.2" and mm440.cpu communication mm440 via profibus.
best regards
