two questions:
when you change a profibus device (that have parameters) for example a encoder, is it necessary load the hardware configuration from step 7 or only make a reset to PLC.
Arethis parameters stored in the electronic of the device or no? (for example a encoder, a scanner or any profibus device )
[?]: Load changed hardware in profibus
Josemi
Josemi
absolute Encoder
The encoder is the same but it haves parameters (preset, resolution, CW or CCW... Is it nedessary reupload the hardware for this absolute encoder if I won't change any parameters (althought this parameters are diferent of default factory parameter
Thanks in advance
Thanks in advance
