[?]: how to make a s5 cable for normal notebook
I want to use s5 in the winxp. Now i got the software. But my notebook only has rs232 interface. How to make a cable 9 to 15.
USB Order No is: PG-USB-Kabel, A-Nr.9359-1 #106214
see here: http://www.ibhsoftec-sps.de/english/Sel ... are_S5.htm
for USB-S5-Current Loop Converter and PC-S5-Current Loop Converter
I don't know if you can make a cable yourself. I use cable PC-S5-Current Loop Converter from Siemens. I was not in want of makikg a cable myself.
So, if you want I will try to do reverse engineering on the PC-S5-Current Loop Converter that I have already and I will send you the schematic and you try to make the cable yourself. Please say me if you want it.
Also, I can give you the above usb cable in half price in comparison with the price that you will see in the link above.
RS232 to TTY (current loop)
Dear friend,
from my experience I tell you:
the solution is good, and cheap.
Personally I use drawing from the link S5_COM_TTY_hardware.zip
https://disk.yandex.ru/d/E7g4Fgp_heD7Uw
https://mega.nz/file/iXJVmBYZ#OBN-qw3q3 ... D5DI6JNcvI
version COM_TTY_v1, FOR SEVERAL YEARS and works fine.
About the soft I use the PG-95 (PG-2000), and is excellent .
All the best ,
dekor
All the best ,
dekor
Re: [?]: how to make a s5 cable for normal notebook
Dear Sir,
please can you re-upload this two files
https://mega.nz/file/iXJVmBYZ#OBN-qw3q36XusGJ0RDvqKXxdCmWMaWcNxD5DI6JNcvI
Dear Sir Mr. CoMod
I have no words to express my gratitude and thanks to you.
Thank you very much for your upload.
