I'm trying to put a button to exit the wincc runtime.
I've already tried the "ExitWinCC()" command, but it closes all the applications and the last time I tried to open it back, there was an error window.
Does anyone knows if it's possible to put a command to shut down only the runtime window?
if it is, how it's done.
Thank you very much
[?] Exiting WinCC runtime with a click button
Re: [?] Exiting WinCC runtime with a click button
Try with : DeactivateRTProject ()
good luck!
good luck!
