i'm looking for
Siwatool FTA --> 7MH4900-2AK01 and for
Multiscale FTA --> 7MH4900-2AL01
[LINK]: SIWATOOL FTA
Parameterization software SIWATOOL FTA
Siwatool_FTA_2007_01_31.rar
http://support.automation.siemens.com/W ... n/27202582
http://support.automation.siemens.com/W ... n/25296061
http://support.automation.siemens.com/W ... n/18714350
See also:Parameterization software SIWATOOL FTA
SIWATOOL FTA is for commissionig and test of SIWAREX FTA.
You can use it Offline, Online You can read and save the parameters,protocol , error buffer and trace data.
Changing data in Siwarex FTA is possible with FULL VERSION of SIWATOOL FTA.
You can find in the SIWAREX FTA configuration packages 7MH4 900-2AK01 for S7 and 7MH4 900-2AK61 for PCS7 V6.0.
dvavezlo
"Siwarex FTA" vs 7MH4900-2AK01
Sorry, guys, I need some help (reg. Siwarex FTA):
Is the soft which is sold by SIEM-S as "7MH4900-2AK01" and the package called "Siwatool FTA" ABSOLUTELY IDENTICAL things?
As I understand, "7MH4900-2AK01" contains some additional features, for ex. - S7 function blocks, which are missing in the soft, mentioned above (in pure "Siwatool FTA" configuration package)
I've got the "Siwatool FTA", but - If they are a little differnet - who can HELP (PLEASE !!!) with the full one, "Siwarex FTA" (7MH4900-2AK01) ?
It's urgent, and I can't wait for a month or more untill it'll come to me from Germany :(
Hope for Your help. Thanks in advance.
frankw
For the FTA's s7 function block, you can download the Getting Starts FTA:
I have not found the software for FTA hardware configration with S7 integration, only FTC.
=== add 2009/06/24 ==========
weijah wrote:i uploaded for you.
here you will find installer for s7
[dead] :/0A8D603E73D ... ED8EE051B8
https://mega.co.nz/#!rRljVQoa!N2QLym7f4 ... ZVp_XL1kG4
The following directories are found on the CD-ROM:
FUNCTION_BLOCK_SIWA_FTA
Function block for operating the SIWAREX FTA in SIMATIC S7
MANUAL
Device manual for the SIWAREX FTA module
in PDF format (several languages)
OCX_FOR_SECURE_DISPLAY
Add on for ProTool for projecting the "secure output" output field
GETTING_STARTED_SAMPLES
Example project for operating a scale with SIMATIC HMI (TP170B)
SETUP_FOR_SIMATIC_S7
Installation of the SIWAREX FTA module in the SIMATIC Manager hardware catalogue.
SIWATOOL_FTA
Parameter software SIWATOOL FTA for Windows (as of Win98)
