[?]: Error in Data Monitor Reports
bantonio
Post by bantonio » Thu Sep 27, 2007 6:28 am
When I open the Webpage of DataMonitor and I press the link for Starting Page, IE open the page /Reports/PublishedReports.aspx and this error appear in the IE page:
Server Error in '/Reports' Application.
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File -->
<configuration>
<system.web>
<customErrors mode="Off"/>
</system.web>
</configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<configuration>
<system.web>
<customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/>
</system.web>
</configuration>
If I press the link Published Reports it happens the same thing.
If I press the link Excel WorkBooks it opens the page /Reports/PublishedWorkbooks.aspx but the error is the same.
Can anybody help me?
