[?]: About the installation of drive ES basic v5.4 CD2
capsute
Post by capsute »
I have problem in the installation of drive ES basic v5.4 CD2,after the completion of CD1,it prompt me to insert the CD2,but when I click the OK button with the CD2 in the CDROM,nothing happen.then I try to install the starter from the CD2 directly,it pop up a dialog frame saying "you are not using the intended setup!please move to higher directory".may someone who know the solution help me?
copy CD1 on HardDisk in any directory,copy contens of CD2 into the directory too with overwriten files,run setup again
