Request: INAT H1 protocol driver
alexisams
Post by alexisams » Tue Sep 18, 2007 11:32 am
I need desperately the INAT H1 PROTOCOL DRIVER full version.
At www.inat.de you can download a 10 hours version just for testing.
Does anyone has it?
Thanks in advance...
danielegger
Post by danielegger » Wed Sep 19, 2007 9:22 am
The demo version is also the full version.
You will see a txt file (H1FREE.DAT) in C:\WINNT\System32\Drivers\ for Win2K or WinNT and in C:\ for Win95, DOS etc.
If you don’t see it you have to copy it or create it in this root.
The file contains a dummy code (00 00 00 00 00 00 00 00).
The correct code for your PC will be generated with the network adapter’s MAC address.
For that you have to contact INAT :(
I think the best for you and all of us is to crack the driver sys file.
Just one more think, if you got one serial code, you can use it on other computers only if you change the MAC address. To do that you can use A-MAC Address Change.
If you get the cracked file, please share !!
Regards
Danielegger
alexisams
Post by alexisams » Fri Sep 21, 2007 12:31 pm
Hello to all of you!!!!
If i have a licensed Inat OPC Server do i have to licensed and H1 protocol also?
Thank you
idikmen
Re: Request: INAT H1 protocol driver
Post by idikmen » Tue Aug 06, 2013 5:15 pm
hello to everybody.
Does anybody got the cracked driver sys file "h1prot.sys"
Thanks alot.
