[LINK]: Hakko Electronics V-SFT Ver.3
Roman
Post by Roman » Tue Sep 18, 2007 3:25 am
Any body have this soft ?
Please share this program.
Very required
gremlin
Post by gremlin » Sun Sep 23, 2007 7:37 pm
I may be able to get it from my mate who used to programme these
will have a look on my way home from work in the week
regards
gremlin
Galli
Post by Galli » Mon Feb 25, 2008 5:09 pm
I'm not sure what version ..
But you can try download..
most
Post by most » Wed Feb 27, 2008 10:39 am
http://plcforum.uz.ua//V- ... 0.rar.html
if you have v2.xx you can download update for v3 in
http://www.hakko-elec.co.jp/index_e.html
i have V-SFT2.2.17.0 and with this update V3 it run ok
brave_eagle
Post by brave_eagle » Sun Mar 02, 2008 11:24 am
Now The last version is 5.0 which support new gereration V8 series
Derno
Post by Derno » Sun Mar 02, 2008 1:25 pm
Thanks, the V2.2.17.0 works ok.
But I have problems to download the upgrade. I go to the download page and fill in my name and other personal item, but when I press download, I recieve a fault in the downloadpage?
The reason ????
gremlin
Post by gremlin » Sun Mar 02, 2008 2:32 pm
what is the fault
i had this prob
you have to select the product you want at the top above your name address etc two check buttons to choose the one you want to down load
you can put any name etc you like it does not check and does not send any info by e-mail etc
cheers
gremlin :shock:
Derno
Post by Derno » Sun Mar 02, 2008 3:00 pm
I klick to download the first selection "V-SFT Ver.3 update" from V2.xx
after filling in my name and all the other questions I klick " Download at once"
I have changed my security level and pop-up blocking but nothing helps.
Thats the warning I recieve.
Warning wrote:pg_exec() [function.pg-exec]:
Query failed:
ERROR: invalid byte sequence for encoding "EUC_JP":
0xeb6c in /lvm07/vuser02/6/6/0037066/www.hakko-elec.co.jp/en/download/download.php on line 106
most
Post by most » Sun Mar 02, 2008 5:13 pm
yuryur
Contact:
Post by yuryur » Tue Mar 04, 2008 2:40 pm
Can anybody show me the soldering pattern of the cable for connecting a PC to the Panel V6 using RJ45
in Russian wrote:подскажите пожалуйста распайку для подключения компьютера
к панели V6 через RJ45
yuryur
Contact:
Post by yuryur » Wed Mar 05, 2008 6:55 am
thanx
but I also want to know the pattern of the PC serial connector DB9 for this cable
Derno
Post by Derno » Wed Mar 05, 2008 11:03 am
MJ1 and MJ2
pin 1 = +SD/RD of RS485 + data
pin 2 = -SD/RD of RS485 - data
pin 3 and 4 = +5V 150 mA max. (output power)
pin 5 and 6 = 0V (signal ground)
pin 7 = RD of RS232C receive data
pin 8 = SD of RS232C send data
Normaly 3 wire connection:
RJ45 pin 7 (RD-RS232C) to PC RS232C pin 2 (TX) (9 pins connector fem.)
RJ45 pin 8 (SD-RS230C) to PC RS232C pin 3 (RX) (9 pins connector fem.)
RJ45 pin 5 or 6 (ground) to PC RS232C pin 5 (Signal nul) (9 pins fem.)
simontew
Post by simontew » Thu Jul 03, 2008 2:18 am
Anybody have Hakko Editor software for GD80T Which is more than 10 year product from Hakko.
But I need the software and cable to upload the program for backup purpose.
Thanks. :roll:
most
Post by most » Tue Oct 07, 2008 10:35 pm
new version 5.3
with the version http://plcforum.uz.ua//V- ... 0.rar.html you can update for new v5.3
http://www.hakko-elec.co.jp/en/download ... ex.html#02
regards
