hi all ,
are there any way to connect the WinCC and microprocessor ( I want to use PIC ) ?
I want replace PLC by PIC .
thanks .
[?]:connect between WinCC and microprocessor PIC/AVR?
Re: [?]:connect between WinCC and microprocessor PIC/AVR?
You really want replace NNNN$ PLC by 1$ PIC ?ducduy wrote:I want replace PLC by PIC .
For study you can use:votuandktd wrote:WinCC <-> OPC Server (make yourself) <-> PIC boardducduy wrote:I am student , I dont have enough money to buy a PLC for my practices exercises . otherwise , I have some small project with PIC , I don't know use VB for create HMI , I want use WinCC for HMI , and PIC for controller .
Very difficult
PC how soft PLC: WinLC or WinAC/WinAC RTX or soft simulator PLCSIM
with HMI PC soft: WinCC and WinCC Flexible Runtime runned on PC
But it is desirable to use 2 video displays - first for Step7/PLCSIM, second for HMI.
![Image](http://img112.spamm.us/img112/4530/2screenanisc3.gif)
Linking ProTool/Pro Runtime V6.0 with PLCSIM V5.0 SP1in Russian wrote:Лабораторию для изучения программирования можно организовать на одном компьютере, но желательно с двумя дисплеями.
Вы можете использовать программу WinLC или WinAC/RTX (выполняющую функции контроллера на РС) или отладочную программу симуляции контроллера PLCSIM
и систему визуализации WinCC или WinCC Flexible Runtime.
Для работы с WinAC/PLCSIM на одном компе с WinCC требуется настроить программный интерфейс аналогично рекомендациям в ссылках
is equal Linking WinCC Flexible Runtime with PLCSIM
http://support.automation.siemens.com/W ... n/13283804
How can you link WinCC to S7 PLCSIM?
http://support.automation.siemens.com/W ... n/21914005
Settings for configuring communications between WinCC and a WinAC
http://support.automation.siemens.com/W ... en/8804489
http://support.automation.siemens.com/W ... en/5884562
