[?]: WinCC flex and S7-200
amet
Post by amet » Tue Sep 11, 2007 6:53 am
WinCC flex and S7-200 PLC both is similation possbly.
Nazar
Post by Nazar » Sun Nov 18, 2007 5:45 pm
Hi...
...as i see, you need to connect PC with installed WinCC Flex and PLC (S7-200)....
...so you can do this different ways:
1. if you have only S7-200, then you must buy siemens PPI cable or braze the same cable yourself...
2. if you have S7-200 with comunication module such as Profibus or Ethernet, then you need only corresponding network device in you PC
good luck...
Dreamer76
Post by Dreamer76 » Sun Dec 02, 2007 9:21 pm
huhu
yes it works good.test it with microwin 4 sp5 simatic s7 v 5.4 and wincc flex 2007
ciao
Dreamer76
